01-09-2017, 09:10 PM | #1 |
62 1/2ton frame swap
Would anyone know or has anyone put a 1969 c10 short bed frame under a short bed 1962 c10 shell? I am just wondering if this would work or if it is going to be a pain. Any help would be appreciated.
01-09-2017, 09:44 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 62 1/2ton frame swap
Pain!
Mounts will need to be built/moved etc, frame horns will have to be cut off and replaced with original frames. Oh and the #'son the VIN and frame won't match which to some won't matter but to many DMV folks is a huge no no. I wouldn't buy one. But the truck is yours, make you happy. Why not swap disc brakes and a new rear from a donor?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-09-2017, 10:06 PM | #3 |
The chassis i was looking at was bagged. Mine has torsion bars and springs in the back. Do you know what newer cross member would work to get mine swapped out to a spring front end? I have checked at mustang two frontends... Everything seems to be for a 1963 and later...
01-09-2017, 10:54 PM | #4 | |
But Found Her 25yrs Later!
. 73-87 front cross is member is what most use to go to coils in the front.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-11-2017, 03:45 PM | #5 | |
I swapped my 62 front end cross member with one from a 72 C-10. Had to wallow out a couple holes but it was mostly a straight forward swap. I ditched the torsion bars obviously and also converted it to a disk brake and PS setup. |
