Front drop spindle problem...
I recently installed 62-70 drop spindles on my '72. I used the 69-70 upper and lower ball joints, and 69-70 outer tie rod end with the conversion sleeve that moves the 72 outer tie rod inward.....
The problem is that now the passenger side tire leans inward terribly at the top..... Where should I start looking.....Thanks.. |
![]() Join Date: Sep 2010
Re: Front drop spindle problem...
I am interested in this also...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
Just on a side note.....
The passenger side spring was removed so that I could better clean the lower seating pocket... Could I possibly not have the spring seated correctly upon reinstalling? To the naked eye, it looks seated on the lower arm and in the upper fixture... just thinking out loud.. |
#4 | |
Could well be a machining issue relative to the stock parts. This would change the front end alignment.
Have you had the truck aligned or looked to see how many shims and how they are oriented on the upper A arm?
I am running CPP A-arms, springs and spindles... I have had it aligned and am told that the only way to fix it is to put a longer A-arm bolts in to be able to put more shims in... To me that is not a great solution so I am looking for alternative solutions before going down that road...
#7 | |
Does it come back to normal.. I think the drop springs are the problem.. has your frame cupped are the sides still 90* to the ground? normal issue with a body's and b bodys, I'd think the truck frame would also suffer from this.. maybe more so as it's bolted/riveted together, not welded |
#8 | |
#9 | |
\______/ the pass side is the one that gets the worst of it.. the top of the c channel bows out compared to the bottom.. and causes issues and need for tons of shims Last edited by James the III; 01-10-2017 at 10:49 AM. |
Thank you for the input... Hopefully this will help the guy that started the thread but my frame was on A frame machine while it was being built...
Rottenwood Garage Member
If you have not been to an alignment shop yet, that should be your first step.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#12 | |
#13 |
![]() Join Date: Nov 2004
Use a flash light and look up into the upper spring perch. This is a small D shaped protusion that the upper spring fits over. You can usually tell something isn't right because the spring will be really close to one side of the cross member opening.
I've done quite a few front spring swaps over the years and I recently was in a hurry and didn't seat the top and had to do it all over again... didn't notice until eveyrthing was done and assembled... wasn't fun.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#14 |
can the upper shaft for the a arm be put in backwards ?
I know they make offset shafts, but haven't looked closely to the stock one to see if it is at all or not.. |
#15 |
Thanks for all of the input ideas. Since I only installed lowering spindles, and reinstalled the stock springs, and only had the pasenger side spring out ( side of my problem ) i feel the spring might be compromised in one of the spring pockets... i will disassemble and look this week.. thx
oh, and btw, i never removed any of the A arms.... |
#16 |
If the spring isn't in and seated, it will raise the front end and cause negative camber (and toe-in) as you are experiencing.
Exactly the opposite (positive camber and possible toe out) when you lower the truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#17 |
Upon inspection, a non-seated spring is my problem. It is offset on the lower A-arm, and one coil is sitting on top of the cup lip....
This will get corrected tomorrow. Thanks to everyone that left comments, they are much appreciated..... |
#18 |
Drive it through some good dips, that will seat it!
