01-09-2017, 10:54 PM | #1 |
Altitude Adjustment- Jet size for lower altitude help please?
Having moved from Wyoming to Mississippi, my truck runs like crap. I removed the jets and I need some idea of replacement jets and other adjustments I will need to make to make it run like a sewing machine.
Here is what I have going on. I moved from 8000 ft altitude to 200 ft altitude. I have a 1967 Chevy C-10 with a 70 Chevelle 396 Big Block, bone stock build, no racing cam or anything special. Running a Holley 0-3310S 750CFM 4bbl Carb. I removed the primary jets which were 72's. Does anyone know what I should replace them with for this lower altitude? Should I also consider replacing the spray nozzles? Would I need to do the same with the secondaries? Any advice would be greatly appreciated, and thank you in advance. I must admit, I am not a carburetor guy. I was told buy an old timer once, if you don't know a Holley, leave it the "F" alone... I did not listen. |
01-09-2017, 11:55 PM | #2 | ||
"I ain't nobody, dork."
Re: Altitude Adjustment- Jet size for lower altitude help please?
The 3310S is a 4160 style carb (rear metering plate), with vacuum secondaries so there is no pump squirter (spray nozzle) for them. Only a pump squirter for the primaries. Stock is usually a #31 if I remember right.
72 jets came in the carb primaries from the factory. It has a rear #21 metering plate that is non-adjustable (no jets) and equal to about a 75 jet. Also what is your timing set at? You should always nail down your timing before a whole bunch of carb tuning. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-10-2017, 12:52 AM | #3 |
I just spent an hour and a half reading your stories on here and WOW! Boy did I get side tracked and derailed..... That is some good, bad and ugly reading material you got going on there. Ha ha ha! So, I am going to try some #68 jets and see how that works, then I am going to check the timing again, though it idles fine and sounds good until I give it throttle. A mechanic at work told me I needed #68 jets and handed me 2 new ones to throw in it... We will see.
01-10-2017, 01:22 PM | #4 |
You went from high altitude with thin air to low altitude with thick air. You now have more oxygen in the air. Therefore, you need more fuel. Going to a #68 would be the wrong direction. I would start with #74, to match the more air you now have.
Need more details regarding what running like crap means. At idle, at 1/4 throttle, throughout throttle, wide open only? Also check Holley's web page. They have a method to calculate jet changes based on altitude change. |
01-10-2017, 03:34 PM | #5 | |
you are lean not rich.. unless you had a lean backfire in the carb and it took out the power valve and it's now rich.. |
01-10-2017, 05:53 PM | #6 |
I believe they came from the factory with #65 jets and set up for sea level. Mine was running too lean so I went to 66,67 and settled for #68 and all is good being I'm in the mountains. I would go back to the #65 and start from there... Ed...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
01-10-2017, 07:17 PM | #7 | ||||
To the OP of the thread. What is your timing set at? What Power valve is in the carb now? Stock PV would be a 6.5 Gary
01-11-2017, 01:34 AM | #8 | |
01-11-2017, 01:41 AM | #9 |
Man.... She is ALMOST THERE!!!!
01-11-2017, 01:48 AM | #10 |
All of this does nothing if it don't run....
01-11-2017, 11:32 PM | #11 |
If that carb is brand new, did you use the carb in Wyoming? Holley jets the carbs for sea level. Your jetting should be right on target with the factory setup. I would be looking at other tune up items.
01-13-2017, 01:10 AM | #12 |
I installed the engine and carb in Wyoming, transported the truck to Mississippi, finished it (drive shaft, brakes and exhaust) and now trying to dial it in to drive. It runs really rough in gear. Idles fine. You may very well be right.
