01-10-2017, 03:52 AM | #1 |
Will this C20 power brake unit fit my c10?
Hi everyone,
I have a 1967 c10 with manual brakes. I have the chance to pick up the power brake canister, master cylinder & mounting hardware & rods off of a 68 c20 that looks in almost new condition. The canister is smaller in diameter & thicker than the canisters I usually see on c10's. I was hoping to use my present master cylinder without unhooking the lines and attempting to install the canister & mount behind it. My questions: 1. Anyone familiar with these know whether this would fit on my truck and install on to my master cylinder? 2. If it wouldn't fit, would the mount that goes on to the firewall fit & could I purchase a canister for a c10 & install it on the c20 mount? All help appreciated! |
01-10-2017, 08:38 AM | #2 |
Re: Will this C20 power brake unit fit my c10?
I think you will be fine with that booster , make sure the plunger rod goes in the master the same length as the one replacing it , there are 2 different depths
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-10-2017, 05:57 PM | #3 |
I wouldnt mix parts like that
01-10-2017, 07:15 PM | #4 |
Moderator
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-10-2017, 08:35 PM | #5 |
You need the whole Power brake unit, with the plunger Rod. Use the pro portioning block in accordance with your brake setup
01-10-2017, 11:37 PM | #6 |
Thank you everyone for the advice & help. I'll see if I can move the master cylinder over & slip it in. If it looks dicey, I can pull it back out of the way & put the master cylinder back.
Thanks again! |
