Old 01-10-2017, 08:34 AM   #1
Guyz55
55 2nd series Rear End swap
In a previous post titled wheels, I should have asked the following question which is
if I decide to swap out the read end in my 55 3100 sb which used read end would be a good replacement . C10 ,Tahoe,camaro
As I indicated , I put out a previous post about swapping out my front brakes to disc and wanting to keep my 6 lug hubs ///im not so sure that's the right way to go given the limited supply of custom 6 lug wheels ....so if I can pick up a used rear end that has 5 lugs would it be that simple to find matching wheels for all for corners ...I'd rather not incur the cost and aggravation of swapping in a rear end and then having to try to find wheels to match different bolt patterns ...
Just not sure which way would be the right way to proceed
Thanx for the help ....
Guyz55 is offline   Reply With Quote
