Old 01-10-2017, 01:02 PM   #1
Ramiro0727
Electric fan install
Hello,
I purchased a 16" American Volt Electric fan. I was wondering when I install the fan. Can I piggy back off the thermostat switch and have on wire going to the fan and the other wire going to my temp gauge in the dash cluster? Or should I get a temp sending unit and mount it on the drivers side of the engine and run that wire to me temp gauge in the dash cluster?
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 01-10-2017, 02:11 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Electric fan install
Most temp senors work off ground.
So if you want the fan to work put a hot wire with relay in line and use it as the ground. The only problem I see is it will be on anytime the temp senor is grounded unless you use a switch also in line to turn it on/off
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-10-2017, 02:18 PM   #3
rcazwillis
You need another sensor. The sending unit for a gauge has a variable resistance. A fan needs a on/off sending unit. Basically, reach this temperature and ground the wire.
rcazwillis is offline   Reply With Quote
Old 01-10-2017, 02:53 PM   #4
Andy4639
Old member
Andy4639's Avatar
The temp gauge itself has nothing to do with the senor grounding. The senor goes to ground and the gauge reads what ever the resistants is but for the fan it's grounded. I would hook it to another senor also are if the truck has ac hook it to the compressor switch through a relay.
Whatever way you do it make sure and use a relay. Fans take a lot of amps.
Old 01-10-2017, 03:01 PM   #5
19671972C10
And dont hook fan power into ingnition power like i did and fried my fan control. Btw Advanced Auto parts sells fan control kits.
19671972C10 is offline   Reply With Quote
Old 01-10-2017, 04:44 PM   #6
Ramiro0727
Thank you all for chiming in. I think I'm going to use a temperature sensor on the driver's side of the engine block for my dash cluster temp gauge. Also my Electric fan did come with a relay switch that I will be using.
Thanks again,
Ramiro
Old 01-10-2017, 10:21 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The temperature gauge sender operates off variable resistance from about 500 ohms cold to 230 ohms hot so I doubt that the relay would ground as the water temperature rises to where you want the fan to kick on. Not only that but if it did fire the relay the sender wire to the gauge would be connected to positive through the relay coil. That might not be healthy for the temp gauge. You could overcome that with a diode which some relays incorporate.
The other problem you might see is the voltage induced when the water temp cools and the relay shuts off that would spike to the temperature gauge through the sender wire.
If I can think of any other reasons not to do it I'll post them. LOL
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-11-2017, 12:09 AM   #8
Ramiro0727
VetteVet I'm going use the relay switch for my electric fan. As far as the temp sensor it wii hook that straight to my temp gauge on my dash cluster. If that will work.
