01-10-2017, 11:16 PM | #1 |
Just another rear axle ID thread!
Ok I pulled the rearend outta my 67 and I'd like to know what it is, but I couldn't match any codes or ID numbers.. it appears to have signs of spring perches at one point. However it looks like it was a decent job(good welds and grinded smooth) regardless I would like to know some about it.. here's some pics
1967 Chevy CST 10 1969 Chevy C/20 Longhorn 1969 K10 Suburban 1972 Chevy Cheyenne Super 10 turned K30 (sold) |
01-10-2017, 11:17 PM | #2 |
Re: Just another rear axle ID thread!
01-11-2017, 02:11 AM | #3 |
The Older Generation
According to the charts it looks to be a 3.73..... The HA is what you use. http://67-72chevytrucks.com/vboard/s...d.php?t=578793 Don't mind the c14 designation. LockDoc
01-12-2017, 01:08 AM | #4 |
Right on. Thanks doc, I had dug up that thread but that C14 threw me off. Any way to know what it originally came from? Or if it's posi? I can't recall the wheel spin trick to determine posi, lsd, all that jazz. Thanks again
01-12-2017, 01:49 AM | #5 | |
Not a Posi. Letters would be "HC" or "JQ" for a Posi in '67. Jack it up so both wheels are off the ground and spin one wheel, If both wheels go the same direction it is a posi, if the wheels go in opposite directions it is an open rear end. LockDoc
01-12-2017, 03:19 AM | #6 |
Cool, thanks again
01-12-2017, 09:19 AM | #7 |
I've been fooled by rear axle id codes enough now I don't even bother checking. After 50 years I'm sure it could use a fluid change and a new cover gasket. And if I was working on it, I'd do a pinion seal as well.
Once you get the cover off, there is no doubt about what is inside.
01-13-2017, 01:05 AM | #8 |
This is true, however I serviced it right before I tore the truck apart, (no miles)and when I have the Cashola I am gonna do an all new 3:73 posi u and new axles and powder coat. But for now I was just curious! Thanks for the reply!
