Old 01-11-2017, 12:49 PM   #1
WarMonger
WarMonger's Avatar
Blazer Frame swap
Question for the experts. I have a 72 K5 that I want to make 2wd. Can I get a shortebed C10 frame and set the Blazer body on it? I mean I know I can, I want to know if there are some serious things I have to do to get the body on, or does the body just lay right on it?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 01-11-2017, 01:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Blazer Frame swap
Shortbed frame is longer than your blazer frame.
It's easier to add the 2wd crossmember to your existing frame.
Lots of threads here:
https://www.google.com/?gws_rd=ssl#q...om&safe=active
Keith
Convert to disc brakes.
Old 01-12-2017, 11:45 AM   #3
WarMonger
WarMonger's Avatar
thanks Lolife I really appreciate the help
1970 C20
-_--_--_- ______
1972 K5
Old 01-12-2017, 08:09 PM   #4
notsolo
notsolo's Avatar
71-72 C10 donor with disk brakes would have many of the parts you will need for conversion, you will still need to fab up some rear spring mounts unless your going with an axle flip. Also driveshaft length will depend on transmission and engine placement.
notsolo is offline   Reply With Quote
Old 01-13-2017, 05:10 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
73-87 front swap crossmember swap works too. Need a 2wd steering box. (just something about the tie rod ends) . You can run with rear leafs unless you want to get creative. Find a 5 lug rear and swap that in or keep with the 6 lug and get a later model Tahoe rear with disc brakes and use a 73-87 c20 front disc crossmember. Lots of 6 lug modern wheel choices... a lot depends on what you want for looks... original or custom.
Rich
1972 K5 Blazer CST Click HERE
