Old 01-11-2017, 01:23 PM   #1
wpotter
wpotter's Avatar
1/2 ton rear axle 5 lug & 6 lug interghange
I have a 1987 1/2 2wd 5 lug truck with 2.73 gear rearend and a friend just gave me a 1/2 4wd 6 lug rearend with 3.73 gears and a gov lock. My questions is do the parts interchange between the two rearends? Can I swap axles or can I swap carrier with ring n pinion? I havent had time to measure so I'm not even sure if they are the same width. Any help would be appreciated. Thanks
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 01-11-2017, 07:01 PM   #2
barry1982
Re: 1/2 ton rear axle 5 lug & 6 lug interghange
I'm not positive about the squares..... but I know a 88-98 six lug is wider than a 5 lug. Attempted installing a 4 x 4 diff in a 2WD..... no go.
barry1982 is offline   Reply With Quote
Old 01-11-2017, 11:38 PM   #3
Rubble
Been about 10 years since I did it,but pretty sure all I did was swapped axles from 5 to 6 lug. I tried it with a 5 lug heavy half axle & the shafts were larger,ended up just using a regular 5 lug axle. Track width was same too.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 01-12-2017, 09:36 AM   #4
TwoFiftyShifter
I did it. My 6 lug axles slid right into the 5 lug diff. 1 Shock mount needed to be moved.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
