Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-11-2017, 02:32 PM   #1
moregrip
moregrip's Avatar
pick your part tools list
I'm trying to gather what tools I should bring to my local pick a part in the event I find something I can't live without! Since its been a while since I've wrenched on these old Chevy's what would you consider essential without getting too over the top?
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-11-2017, 02:35 PM   #2
chrismoore701
chrismoore701's Avatar
Re: pick your part tools list
Socket set, pliers, wire cutters and screw drivers
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 01-11-2017, 02:44 PM   #3
notallthere
A good sharp knife, wagon to carry all the tools and parts. If you need electrical take a small 12V battery for testing. WD40. I also have an 18V impact that I bring to make things a little faster.
notallthere is offline   Reply With Quote
Old 01-11-2017, 03:57 PM   #4
tucsonjwt
It depends on what you are looking for. Your best bet is to bring a full set of tools and leave it in your vehicle outside. Once you find what you want, go back and get the specific tools you need and put them in a small canvas tote bag.
If you want to find out if an electrical component works, use that 18V battery from a cordless drill. Get two pieces of household romex wire 12 ga or 14 ga) and shove the wire into the contacts of the battery. Use two alligator clips and some small stranded wire to connect to those wire pieces, and connect the other ends of the stranded wire to the contacts on the electrical device (you can use two more alligator clips for that also.) You can use the alligator clip and wire from a couple of 12V continuity testers to simplify the process.
You should really consider what you need first, then go hunting.
tucsonjwt is offline   Reply With Quote
Old 01-11-2017, 03:58 PM   #5
vht
Some stuff on later one's is metric, 10mm instead of 3/8's and so forth. 13/16 socket if you have to take out seat belts, breaker bar and 1/2 drive ratchet. I take my battery powered drivers, 1/4 in set, small set of torque bits, hammer, phillips bits, and a pry bar. I just went back and got a steering wheel because the last time I didn't have a puller with me. No matter what you take you'll be missing something.
vht is offline   Reply With Quote
Old 01-11-2017, 04:31 PM   #6
notallthere
I almost forgot this one and this is not a tool but just to help you out. Bring water, and a small snack if you are going to be out there for a while. You would be surprised at the amount of calories you burn or water you loose wrenching out in the middle of a wrecking yard.
Old 01-11-2017, 04:36 PM   #7
3drburb
All the tools above plus gloves, eye protection and cardboard or some to lay or kneeling on.
3drburb is offline   Reply With Quote
Old 01-11-2017, 07:59 PM   #8
Matt Man
Matt Man's Avatar
I bring much of the above. I would also bring vice grips they have helped me a bunch.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-11-2017, 08:08 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Bring every possible tool that you can lock in your truck. Walk the yard with nothing other than a bottle of water. If you find something, get your hand stamped and go get the tools you need out of your truck. This beats wondering and wandering around with 100 lbs of crap.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-11-2017, 08:56 PM   #10
72 tigger
72 tigger's Avatar
Vise grips are handy
72 tigger is offline   Reply With Quote
Old 01-11-2017, 10:19 PM   #11
flashed
Battery powered Sawsall .
flashed is offline   Reply With Quote
Old 01-12-2017, 03:14 AM   #12
El Dorado Jim
I have a box of metric and a box of standard tools i bring to the wrecking yard and a little red wagon,i walk the yard first ,always carry my leatherman tool on me, if i find something i cant get with that, i go back to my truck and get whatever box i need and the wagon and go back in and get what i need....i put these tool boxes together with all us made tools from garage sales, i dont use foreign made tools,they are junk,
El Dorado Jim is offline   Reply With Quote
Old 01-12-2017, 08:52 AM   #13
moregrip
moregrip's Avatar
thank you for all the input! it helped me quite a bit! I have my tools list together!
Old 01-12-2017, 05:49 PM   #14
duallydude63
what i like to do is go inside & make sure they have what am lookin for then go back to my truck and get the tools i really need no reason to take all the tools in if u dont need them !!!
duallydude63 is offline   Reply With Quote
