01-11-2017, 05:33 PM | #1 |
1971 Chevy wiring problem HELP!!
I have a 1971 chevy 4x4. I just installed the new wiring harness from American auto wire. Great kit easy to install love it!! Here is the problem. Everything works great except when I turn the head lights on the front signal lights don't work right. They work fine with the head lights off. With the headlights on both front turn signals stay on but the side markers and the tail lights signal fine.. The dash turn signal indicators also stay on but do blink when signaling
Weird thing is the same thing was going on before I rewired the whole thing. The only thing I did not replace is the signaling wiring and circuit in the steering colomn. Could this be it? |
01-11-2017, 05:40 PM | #2 |
Re: 1971 Chevy wiring problem HELP!!
Ground wires are usually the gremlins that cause headaches like this, check your bulbs up front, ground wires to all turn signals and marker lights and dash ground....Good luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
01-11-2017, 05:40 PM | #3 |
mite want to check your ground wire(s)
01-11-2017, 10:25 PM | #4 | |
01-11-2017, 10:34 PM | #5 |
you guys are the best thanks again!!!!! Ill get to it tomorrow and let you know how I make out!!
01-12-2017, 12:02 PM | #6 |
just wanted to thank you guys! Replaced led bulbs cleaned out front signal sockets cleaned grounds all is well!!!!
01-12-2017, 12:08 PM | #7 |
Cool! Glad you were able to get your lights working correctly.
