Old 01-11-2017, 08:37 PM   #1
prjab95
Question rear end fluid?
Anyone know what rear end fluid weight is used on 95 sierra 2wd & how many exactly? I started leaking from pinion seal & need to replace!
prjab95 is offline   Reply With Quote
Old 01-11-2017, 08:38 PM   #2
sntrym95
sntrym95's Avatar
Re: rear end fluid?
80w90. 2 quarts or so if empty.
Mike
sntrym95 is offline   Reply With Quote
Old 01-15-2017, 01:17 PM   #3
diveplane
Re: rear end fluid?
correct i swapped mine
and buy the pre made gasket for it, lot easier than a tube of silicon.
diveplane is offline   Reply With Quote
Old 01-15-2017, 01:18 PM   #4
diveplane
Re: rear end fluid?
could never understand why they didn't put a drain plug also in the diff
like trannys.
