rear bounce
I have lowered my truck 5" with 3" coil springs & 2" blocks. I have relocated the shocks. New shocks. I still have a bounce in the rear end. Almost like no shocks. Any ideas?
Thanks, Lynn |
Re: rear bounce
do you have the shocks as vertical as possible? if close as a 45 degree angle you won't get much travel on the shocks..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Re: rear bounce
I used the CPP shock relocation kit. They are a lot better than they were, but no, not vertical.
![]() Join Date: Sep 2010
Re: rear bounce
do you have the short shocks or standard shock...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
Moderator
![]() Join Date: May 2007
Re: rear bounce
If all else fails a couple bags of concrete in the bed will smooth out your ride.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Aug 2013
Re: rear bounce
Try a different shock relocation kit? CCP kit moves them forward while the No Limit kit moves them to the rear.
http://www.classicperform.com/tech_a...-Solutions.htm http://nolimit.net/tech-center/67-c1...on-kit-1963-72 |
Re: rear bounce
I have standard length shocks. I was under the impression stock shocks could be used. Did I assume wrong?
Re: rear bounce
hey 30 I,m from buck creek over near lake blalock
Re: rear bounce
Lowbuck, been there many times.
Re: rear bounce
CPP supplied shock #4095G with their 4" spring kit. Came in a CPP box.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
Re: rear bounce
My 3" springs did not come with shocks.
Re: rear bounce
I was able to measure the angle of my shocks. They are leaning 15 degrees forward and 15 degrees inside at the top. What angle is too much?
#13 |
Re: rear bounce
Lynn, my '71 GMC has 4" springs, 1" lowering block, shock relocators, shocks, & adj. panhard.... all CPP. I think it feels bouncy in the rear at Interstate speed. Particularly on concrete overpasses with expansion joints. Usually has no weight in the bed. I wonder if it's due to a combination of spring rate and shock valving. The front has 2.5" dropped spindles w/1 coil cut. The bounce bothered me worse a couple of years ago when I first changed the parts but I think i got used to it. Feels better now.
#14 |
Re: rear bounce
that is fine..
#15 |
Re: rear bounce
I guess it will have to live with the bounce.
#16 |
Re: rear bounce
Use a shorter shock. Probably almost bottomed out and wont valve correctly that way. Im using fronts in the rear as others had on here.
#17 |
Re: rear bounce
PM sent
#18 |
Re: rear bounce
You likely installed them upside down. Remember these shocks don't have dust shields. The exposed rod goes to the top not bottom.
#19 |
Re: rear bounce
My stock shocks have dust covers. Monroe
#20 |
Re: rear bounce
did you purchase for rear? Front shocks have different dampening specifications.
#21 |
Re: rear bounce
My truck is a leaf truck, but I have stock length front shocks all the way around. Relocated upper mount to unused second hole in OEM mount and have no issues with bounce so I think issue isn't that.
#22 |
Re: rear bounce
I have rear shocks on rear of truck. Front is not a problem. I have shocks mounted correctly, dust cover up.
