Old 01-12-2017, 12:48 PM   #1
Crazy Rusty
Crazy Rusty's Avatar
Question 65 front end rebuild recommendations
Doing a frame off on a 65 stepside. Already finished off the back end with a 6" static drop but starting on the front end now. Other than the drop, I'm staying fairly original with the rest. 6 lug, 15" tires, drums on the back, just had the 292 machined, 4 speed tranny.
Everything is stock on the front now so after perusing CPP and Brothers catalogs I believe I need to get the following:
Power Steering Conversion kit from CPP
Firewall Brake Booster kit from CPP (disc/drum)
Upgrade Drop Spindle Wheel Brake Kit from CPP (so discs up front)
Front Shock Re-Locater kit from Brothers
Front Shock Support Bracket from Brothers
Drop springs/shocks (already have those)
Front Sway Bar from someone
Anything I'm missing? I'll use my original control arms... Just making sure I order everything at the same time
Thanks for any assistance!
Crazy Rusty is offline   Reply With Quote
Old 01-12-2017, 01:13 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 65 front end rebuild recommendations
I would look at Early classic enterprises, CPP has horable customer service and I've heard brothers is same unless you go in person.
Ive used ECE on rebuild kit and several other small projects and have always had excellent customer service as well as quality.
Just my $.02
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-12-2017, 04:25 PM   #3
Crazy Rusty
Ya I've experienced that with CPP before, it definitely gives me pause, especially on the power steering kit that appears to only be available there (though obviously I could just buy the pieces separately).
I like ECE but their site is hard to navigate for me. Things don't have much of a description, etc... I'll give them a call and maybe they can compile a list.
Old 01-12-2017, 05:47 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I would also check with ECE first. Most of my build was from trades, exchanges for work/welding, and swaps. The items I did purchase for my suspension/chassis were from ECE (spindles, sway bars, shock relocators, rear track bar).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
