Old 01-12-2017, 01:33 PM   #1
bigmac73
bigmac73's Avatar
rear suspension upgrades with stock height
Guys,
will this set up work with stock height? Is anybody running a set up like this??
http://www.classicparts.com/1963-72-.../#.WHe9W2q7p7g
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-12-2017, 04:07 PM   #2
bbbc10
Diggin The SquareLife
Re: rear suspension upgrades with stock height
I'm sure ppl are running but why do u want to run it at stock height when u can upgrade to drop springs for free?
bbbc10 is offline   Reply With Quote
Old 01-12-2017, 08:54 PM   #3
PGSigns
PGSigns's Avatar
I would look into this setup. They are vendors here and well engineered system from folks that know how to make one handle.
Jimmy
http://www.nolimitengineering.com/pr...tegory=6157547
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-16-2017, 02:23 PM   #4
bigmac73
bigmac73's Avatar
Jimmy
I checked out the link but it states that it will drop truck approx 5 inches,
I want to keep truck at a stock stance and height
Mike
Old 01-16-2017, 09:53 PM   #5
PGSigns
PGSigns's Avatar
If you are going to leave it stock height I would look into swaybar and shock upgrades. Then a longer tack bar. If you really want it to handle better dropping it some will reduce the roll center and a simple 2/4 drop makes a big change.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-19-2017, 12:50 PM   #6
JohnJ@RideTech
JohnJ@RideTech's Avatar
Check out this link and let me know what you think. It will lower the ride height slightly, but overall handling and steering geometry will be improved.
http://www.ridetech.com/store/1963-1...ip-system.html
-Easy to install - direct replacement for factory suspension - no other modifications necessary
-RADICAL improvement to ride quality and handling performance
-Composite rear leaf springs offer linear spring rate and saves 70lbs of unsprung weight!
-Vehicle-specific dual-rate front coilsprings offer the best of both worlds...ride quality AND crisp handling
-Delrin front control arm bushings eliminate unwanted movement and stiction in front suspension
-Tall balljoints dramatically improve OEM camber curve to give your car a much more stable feel through the corners
-Larger front swaybar minimizes unwanted body roll through the corners
-Delrin swaybar bushings eliminate unwanted movement and stiction in the swaybar to improve ride quality and handling performance
-Vehicle-specific RideTech HQ series rebound adjustable shocks offer the ultimate in ride quality and handling performance
This is the kit that is being installed on our 48hr C10 build right now at Barrett-Jackson.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 01-22-2017, 07:52 AM   #7
bigmac73
bigmac73's Avatar
Thanks but I am not lowering the stance on the truck i will just replace the trailing arms and new springs and bushings in the rear i guess
Mike
