Old 01-12-2017, 01:36 PM   #1
moregrip
moregrip's Avatar
static drop vs C-Notch
In general at what static drop point do you need a C-Notch? Are there some ROT (rules of thumb) out there?
Starting with a 4/6 and then maybe 5/7 and 6/8; thank you
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-12-2017, 01:40 PM   #2
UKNOWME
UKNOWME's Avatar
Re: static drop vs C-Notch
I believe this will become an opinionated question so my opinion is 6" in the rear or greater. It kind of depends on the way you drive also.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-12-2017, 02:04 PM   #3
Noxin
with my 6" rear flip im about 2" from axle to frame. C notch is probably needed at this point but mine is not a daily driver so less cutting the better.
Noxin is offline   Reply With Quote
Old 01-12-2017, 03:15 PM   #4
moregrip
moregrip's Avatar
so maybe a slight can of worms lol, my starting point is going to be the Belltech 4/6 and then I'm probably heading to a 5/7 or 5.5/7 from there.
Old 01-12-2017, 03:39 PM   #5
UKNOWME
UKNOWME's Avatar
Just notch it and get it over with.
1964 Chevy c10
Old 01-12-2017, 03:54 PM   #6
evan
evan's Avatar
Is there a preferred c-notch and flip kit? I was thinking of just going with the Belltech since they seem pretty reputable.
https://www.summitracing.com/int/par...mc/model/c1500
Evan B.
evan is offline   Reply With Quote
Old 01-12-2017, 04:03 PM   #7
bbbc10
Diggin The SquareLife
if u don't plan on hauling anything or towing than u can go 6" anything over that ur gonna need a notch
bbbc10 is offline   Reply With Quote
Old 01-12-2017, 04:04 PM   #8
bbbc10
go with the belltech had it on mine an that is the best notch for c10s that is bolt in
Old 01-12-2017, 05:59 PM   #9
moregrip
moregrip's Avatar
thanks, my Belltech 4/6 drop came with the C notches.......I should probably just use those! maybe I'm overthinking the whole c notch thing.
Old 01-12-2017, 07:37 PM   #10
SkinnyG
SkinnyG's Avatar
I have a flip on heavy leafs, I'm not sure the drop, but the tops of the tires are higher than the tops of the fender arch.
I also notched the frame at the time.
I find that when the truck is heavily loaded (I've mistakenly had 1700lbs of sand in the back), the bed floor hits the pumpkin before the axle tubes would have hit the frame.
If I were to do it again, I would not have notched my frame.
On the other hand, a notch might be worthwhile when hitting a bump mid-corner, as the one wheel will go up a lot higher in the instance, and a notch might be beneficial.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-13-2017, 12:36 AM   #11
FullOutPwr
flip kit and sagging springs and I'm on bump stops.
67 C10
Choppin block backhalf
KP Components front dropmember
US Mags Rambler 20s
FullOutPwr is offline   Reply With Quote
Old 01-13-2017, 12:48 AM   #12
SkinnyG
SkinnyG's Avatar
The original bump stops? You probably should remove those.
Old 01-13-2017, 08:30 AM   #13
JWall
Frequent Flyer
JWall's Avatar
I believe that. When I bagged my truck I actually welded in a plate with a threaded hole for an adjustable bump stop into my notch to make the notch smaller.
The rearend would've hit the bed floor before the axles bottomed out in the notch.
I think you could probably get away without a notch but I've never ran one without it. You could always add it after a test drive if needed.
Here is the added plate I mentioned...
- Justin
1 Owner 1976 SWB
Old 01-13-2017, 10:50 AM   #14
moregrip
moregrip's Avatar
Attachment 1610360
good info, thank you!
Old 01-13-2017, 11:17 AM   #15
SCOTI
SCOTI's Avatar
Agreed. If you utilize 'all' of the c-notch, the differential can/does hit the bed floor bracing.
For optimum driving experience, keep the drop mild or plan to alter stuff beyond a 4/6 drop. The constant pounding of the differential against the floor or front tires buzzing the wells is annoying (it's common to start buzzing there w/tires over a certain height).
The difference of the drop on my old 74 (somewhere in the neighborhood of 5/7 - 6/8 static) vs my dually (it can plant the frame rails) is night & day because I planned to do the necessary mods to allow no contact @ the lower driving heights. Driving around LOW (>5/7 drops) w/no interference really makes a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-13-2017, 12:22 PM   #16
moregrip
moregrip's Avatar
copy all, is a standard C-notch (non raised frame rail) enough for a 5/7 and/or 6/8 static drop truck bed not-withstanding, obviously in general terms (not gospel)
Old 01-13-2017, 01:33 PM   #17
SCOTI
SCOTI's Avatar
Read the link for additional info. They get the job done but ultimately are a compromise....
http://67-72chevytrucks.com/vboard/s...d.php?t=457037
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-13-2017, 02:24 PM   #18
moregrip
moregrip's Avatar
that was extremely eye opening!
Old 01-13-2017, 03:32 PM   #19
SCOTI
SCOTI's Avatar
Agreed.
Many trucks have gotten the bolt-in c-notches & not suffered catastrophic failure but it sure makes one think about how much strength is sacrificed if/when you don't need the full range of the notch (because other items will interfere before then). I like to modify stuff but I want it as safe as possible when done (for everyone else on the road around me as well as my own well being). Just something to be aware of.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-13-2017, 05:38 PM   #20
Tom
driving is in my blood
Tom's Avatar
There are hundreds if not thousands of c-notched 1tons pulling max trailor ratings around for years with no issues. There are tens of thousands of 1/2tons with notches and full loads constantly. Honestly, how many of you have met someone who had a c-notch fail? You don't think this weak c-notch might not be a giant, glaring bright red light of liability doom in lawyers eyes if it were the case? To the point they wouldn't allow the company to market them....
Old 01-13-2017, 07:27 PM   #21
SCOTI
SCOTI's Avatar
The info doesn't say bolt-in c-notches will fail but that doesn't make the information calculated any less true. I would bet a lot more people would think twice if they knew exactly how much the bolt-in notch they planned to use was compromising the frames strength.... especially when the differential will likely impact w/the bed floor before the entire depth of the notch is utilized.
I personally have never known someone that had an issue or failure. But when I searched for info on it (after Lakeroadster did the number crunching analysis for me based on my set-up & materials), I found 3 instances of frames that bent @ the notched area via the www & all were 88-98 ext cabs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-14-2017, 01:31 PM   #22
lilpoindexter
lilpoindexter's Avatar
I flipped my 1978 short step rear axle...but i didnt have the heart to cut the frame. I cut the bump stops off and put the little mushroom bumpstops from energy suspension right on my frame rails. I haven't looked in a while but there was 2 or 3 inches between the axle tube and frame rail. One of the mushrooms was split after several years of use...so i know the tube contacted the axle at some point. My truck is a half ton, and i fill it with 400 or 500 pounds of junk maybe 4 or 5 times a year.
lilpoindexter is offline   Reply With Quote
