New Headers
Got my new 1" 3/4 Headman Headers installed and was wondering will I still be able to do a 4/6 drop, It looks like I have plenty of clearance (About 10") I'm doing 2" 1/2 stainless exhaust to the mufflers and tailpipes.
Diggin The SquareLife
Re: New Headers
Yea ur headers will scrap now an then....i had long tube headers an they scraped an messed up the flanges an caused exhaust leak....i ended up going to shorty headers
![]() Join Date: Feb 2004
Re: New Headers
The flanges would be the issue. They don't like scraping.
Re: New Headers
Does anyone make a 1"3/4 shorty headers? I just paid 450 for these and installation, bummer.....
Re: New Headers
have you looked at the newer Hedman mid length for lowered C10s
Cruzzzn' Vet
Re: New Headers
Just stay away or drive around parking lot bumps, remain forever VIGILANT!
Re: New Headers
I've heard that early 70's chevelle headers will work and give you more ground clearance. I'm putting a 454 in my K10, ground clearance not a problem, but I have a new set of hedmans for a chevelle I'm going to try.
Re: New Headers
On my 78 step side I have full length headmen headers and a 4/6 drop . I run rally wheels no problem with clearance . my sons 2wd 82 k5 blazer 4/6 drop different story . bought it with the unknown brand headers in pic. I replaced with headmens . no issues New headmens have ball and socket collectors no leaks or flanges to scrape
1978 c10 stepside 4/6 drop 350 vortec crate 2011 camaro ss2 6.2 automatic 2017 tahoe lt 2002 silverado lt 1500 5.3 automatic. 1981 el camino |
Re: New Headers
guess u have flatter roads where u live
Re: New Headers
The rough mountainous roads of Texas must be treacherous
Re: New Headers
Your engine bay looks great, job well done. I have headmen mid length on my 86 and no issues.
It would be nice if your exhaust guy could keep the exhaust tube size consistent. Over the step down in pipe size. I know its a small thing to some folks. I'm a bit on the picky side when spending money. Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan Last edited by 1970pelle; 01-14-2017 at 07:03 PM. Reason: added stuff |
Re: New Headers
I thought I would have to go one size smaller from the 3" dumps from the headers? Like 2 1/2" all the way to the tailpipes. so it creates some back pressure?
#13 |
Re: New Headers
I am not trying g to start a war, but in the last few years, the old wives tale on back pressure may have been disproven. Do not be afraid to go big if you got the space. I also have read somewhere that 2.5 mandrel bent flows better than certain styles of crushbent 3". Do a search on YouTube for roadkill garage. Great show and great guys did a back to back with different size exhaust and open header.
I just bought a header back system from Summit. It's Pypes brand, it was $200 more than the other kits, but it came with an x pipe and your choice mufflers. It has great reviews for our trucks, stainless, **** ton of clamps and hangers, and the only off the shelf 2.5" for the price. |
#14 |
Re: New Headers
I have 3" exhaust on mine wth stock 350
#15 |
Re: New Headers
I couldn't find a 2.5 system when I was looking for my K10. I ended up getting 2.25 and now with the 454 swap I could use 2.5 or 3 wouldn't hurt.
#16 |
Re: New Headers
I jus took mine to the local muffler shop an they charged me 420 to do my exhaust sounds mean for 350
#17 |
Re: New Headers
If that a mandrel bent exhaust, that's a great deal. I tend to not pay people to do anything for me. I am way to anal and am never satisfied. Regardless of what it is, house work, plumbing even alignments on my car.
I just had a motorcycle frame stripped and powder coated. It was the first time that I can remember that I got what I was promised. It was great. I gave extra money because it looked so good. |
#18 |
![]() Join Date: Jul 2000
Re: New Headers
I kinda doubt that, unless it was a specialty shop. I mean, I'd be surprised if there's a muffler shop in the entire Dallas area with a mandrel bender.
I ended up using an inexpensive mandrel-bent exhaust kit from HeartThrob. And then and modified it to connect to my Patriot headers using mandrel-bent sections from Summit Racing and header extensions from Hedman. I just can't handle crush bends that effectively turn 2.5" pipes into 2.0". And talk about ground clearance! The Patriots have a ton, but they are not without their problems. ![]() ![]() ![]() ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#19 |
Re: New Headers
That's great info. I like the ground clearance. I am dropping mine as well. I am going to notch the cross member for the exhaust rather that run under with the extension. It's free that way and exhaust is straighter and should be easier to plumb into my Pypes x pipe.
#20 |
driving is in my blood
Re: New Headers
I can't see 4" drop giving issues. My 78 is 5" drop and hits the collectors if I'm not carefull but they still seal fine.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
