Pre-Bent OM Brake Lines ?
I need to change a Brake Line on the back of my '72 C-10. Is the quality all the same? Or are some better than others out there? I just need a regular steel Pre-Bent Line with the Factory type metal wrapping on it.
Also where would be the best place to get one at? Thanks
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
Re: Pre-Bent OM Brake Lines ?
I've used Inline Tube several times, and have always been satisfied.
www.inlinetube.com Or more specifically http://www.inlinetube.com/_p/prd14/2...lines--ctb71r1 (Not sure if that's exactly what you're looking for)
1970 SWB Build |
X2 on Inline Tube.
If it's the rear line there isn't any tight bends. You could measure and get one at Napa. It has the wrap on it and is easily bend by hand over your knee. It will be cents that way compared to dollars. If you were doing the front ones or all of them a kit would save time. I understand getting a kit to save headache, but I'm cheap
-Cody |
Any parts store I should say.
-Cody |
Just wondering why you are changing only one line. Is it damaged, or is it rusty? If it's rusty, might be worthwhile to change them all, just to be on the safe side.
Also wanted to add that lots of good things have been said about cupro-nickel brake lines. Easy to work with, resist corrosion, etc. etc. etc.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
Appreciate the replies.
#8 | ||
"I ain't nobody, dork."
I installed an entire set of brake lines on my 1972 GMC from Inline Tube and they are great!
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
go to any parts store, buy your lines and bend them yourself using a bender tool
I usually end up changing the rear by itself because I wreck it changing the brake hose, at the coupler under the cab I just cut the rear line and use a socket and a wrench. I have done the rear many times without a bender, but I do my own all around and cut/reflare where I need to when the pre-lengths are too long.
-Cody |
![]() Join Date: Sep 2005
Ive used i lie tube several times i ordered a whole kit but the axle lines didnt fit so they had me send my old lines in and they scaned them and made new ones and sent them back at no charge, turns out i had a 72 rear end instead of tbe 71 rear it had been swaped , i expected to have to pay more but they took cars of it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Just because one section of line is rotten doesn't mean the rest will be equally rusted. If you look under the truck and they all look rusty, by all means swap them all out. I usually do only one because the only reason I am replacing is because the nut into the caliper or cylinder is rusted onto the line, which is due to exposure to the highly corrosive brake fluid and I end up wringing it off. I anticipated this when changing front brake hoses on my K2500 last summer, so I ordered the section that crosses the cross member and goes to the passenger side hose. The driver side I figured I could make easily. As it turns out soaking with PB Blaster did the trick and for once it came off with ease. The original line was in such good condition I elected to put that back in and keep the Inline section for the future.
The rear axle line I have bought from Inline for an HO52. It went in so easy it about jumped on there all by itself. Figure that's all the line that is down below the frame. The hose passes up into the frame, and the lines in the frame are in a much less vulnerable place. So, I only replaced the axle section...because it wrung off at the wheel cylinders (on a K/20 I had) Now...if the truck was an 88-98 I'd go ahead and replace every line under the truck including brakes, fuel, and fuel return. Somehow in the 16 years between '72 and '88 GM managed to go backwards and use crappy made-to-rust tubing. I think that is made out of recycled 73-77 Chevy Truck sheet metal ![]()
#13 | |
By the way, if anyone is counting, that's right, I haven't done any brake work on it in 16 years, lol. I've kept the miles down on it and it's also the way I drive. When I see a Red Light ahead I start backing down right away. I also downshift quite a bit. Funny as lots of times the guy in the lane next to me races by, then hits his brakes hard to stop. I'm backing down as mentioned and by the time I get there the light is now Green and I zoom by him leaving him in the dust, lol. BTW, I also changed the Front Pads, but the Rear Shoes are still good.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan Last edited by C10 - C90 Bill; 01-13-2017 at 11:14 AM. |
