Old 01-13-2017, 01:35 AM   #1
msg
What grease to use on door hinge replacement?
Before I spray some white lithium grease into the sleeves of the hinges, thought I'd ask around. Is there a best type to use in the sleeves and around the pin?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 01-13-2017, 10:52 PM   #2
andyh1956
Re: What grease to use on door hinge replacement?
White grease is what's recommended, or ATF for regular maint. But yours look disassembled, I would be tempted to use #2 EP (Red Chassis Grease)
andyh1956 is offline   Reply With Quote
Old 01-13-2017, 11:21 PM   #3
msg
Thanks for the reply, I asked the mechanic that helped me break 2 of these apart and he recommended white lithium grease, said the lithium holds up really well. But now I'm curious, what would be the advantage you think in the #2 EP?
Old 01-13-2017, 11:30 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I used white lithium grease.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-14-2017, 11:07 PM   #5
andyh1956
The shortrun advantage would be it's a thicker viscosity. The longrun disadvantage MAY be that by being thicker it would hinder future lubrication attempts when using white spray lithium or atf.
Old 01-15-2017, 02:07 PM   #6
leonphelps
3m clear silicone paste. once you start, you will use it for everything.
leonphelps is offline   Reply With Quote
Old 01-15-2017, 11:29 PM   #7
andyh1956
I have a tube of Dow-Corning silicone lube that I bought to use on O-Ring installations, but you're right, it gets used for everything. I even put some on my lips when the wind was chapping at them the other day!
Old 01-16-2017, 12:34 AM   #8
Rogue
Airport Bum
Lube-ri-plate
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 01-16-2017, 09:40 AM   #9
msg
All good to know, I of course jumped the gun and used white lithium grease after talking to the resto garage guy garage that helps me from time to time. I am curious on the silicone paste, and the Lube-Ri-Plate..although that site has tons of products. Rogue, do you use any particular product? Or different ones for different applications?
Old 01-16-2017, 10:59 PM   #10
jtrichard
ROGUE is most likely talking about this ( Lubriplate Mo-Lith No. 2 ) http://www.skygeek.com/lubriplate-m0...ueAaAmAF8P8HAQ
jtrichard is offline   Reply With Quote
