01-13-2017, 10:25 AM | #1 |
Does a Suburban Font Bench Seat Work in a Truck
I,m sure someone here has done this or tried. Are the tracks the same? Do the suburban seats tilt forward to get behind the seat?
Never a failure, Always a lesson! 1968 Chevy SWB Fleetside ECE 4/6 327/350 1987 Chevy V20 Scottsdale 4X4 350/400 4.10 1987 Chevy Custom Deluxe SWB 305/7004R4 1991 Suburban Silverado V1500 4X4 350/700R4 2015 Chevy Crew Cab SWB (Daily Driver) 5.3 |
01-13-2017, 10:26 AM | #2 |
Re: Does a Suburban Font Bench Seat Work in a Truck
Its a 1986 Suburban seat and I have a 1986 C10 regular cab.
01-13-2017, 02:24 PM | #3 |
I was wondering the same thing for my '77. I was hoping to find something with a center console and bucket seats that was a direct/slightly modified fit.
01-13-2017, 04:08 PM | #4 |
Ive never had a suburban bench but i know you can take the rear out of a crew cab and switch the tracks and it bolts up in the front. If its not split im willing to bet it would probally bolt with the tracks changed. If it is split you would probally need the mounts on the floor to weld in the truck like you would buckets but im just guessing here. I have a single cab seat in the front of my crew cab with the stock tracks i just needed to flatten the rear mounts down some. These year trucks seem to be pretty interchangeable if your willing to do minor mods
01-13-2017, 05:29 PM | #5 |
I don't think it will fold up though. I have a burb seat in.my 84 K10 and it won't fold.
1982 K10 SWB 1987 V20 - Sold - Doh! |
01-14-2017, 11:53 AM | #6 |
Suburban front seats do not fold.
01-14-2017, 12:14 PM | #7 | |
Is there a reason why it has to be a Suburban Bench? I'm just curious, I guess, on why you would swap bench for bench, that doesn't fold? And of course, I'm assuming, that you have a bench in your truck.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-15-2017, 03:23 AM | #8 |
Burb bench seat will work in a regular cab if you use the regular cab tracks and You can swap the fold mechanism from the standard cab bench seat.
I used a burb bench as the rear seat in my 2wd CCSB, used the rear seat brackets and swapped the fold mechanism over.
CHEVY ONLY |
01-15-2017, 11:29 PM | #9 |
How do you swap the fold mech? As far as I can tell it's part of the back.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
01-16-2017, 03:06 AM | #10 | |
I'd have to look at one of each seat to remember for sure, but it seemed like it was pretty simple...
CHEVY ONLY |
01-16-2017, 03:16 AM | #11 |
Only picture I can find
CHEVY ONLY |
01-16-2017, 10:38 AM | #12 |
I have a few seats up in the attic, that I have torn down to restore/recover. I was curious about his too. I will go up and look closely to see how the hardware comes off. I would just be a matter of pulling back the foam enough to see.
01-17-2017, 12:22 AM | #13 |
It's not under the foam, it's under the plastic cover. The frames are the same
CHEVY ONLY |
01-21-2017, 10:19 PM | #14 |
I don't believe so. I swapped my front bench in my 84 crew cab into the rear. The rear seat was hammered. We unbolted everything trying to figure out how to get the front to fold. Only way we figured was to swap the covers. Didn't bother for now. Next nice day maybe I'll pull the cover off the old rear seat. And see whats' going on.
01-22-2017, 05:18 PM | #15 | |
CHEVY ONLY |
02-02-2017, 01:28 PM | #16 |
So, I finally got a pick of the truck seat folding mechanism. It is all part of the seat back. There is no way of swapping, unless your swapping the whole seat back to the Surburban bottom seat frame. Is this what you did, when you said you swapped them, so it would fold?
