01-13-2017, 03:46 PM | #1 |
Need advice on removing steering wheel hub
This is my first crack on removing my steering wheel and I'm stuck at the hub. Do I need a steering wheel puller to remove the hub? Thanks in advance on any help!
- Jeremy |
01-13-2017, 04:16 PM | #2 |
Re: Need advice on removing steering wheel hub
Of course you need a steering wheel puller, you always need a steering wheel puller...use the puller in the straight across 5/16 bolt holes and pull it. You didn't have to remove the wheel from the hub to do this. You can use a harmonic balance puller if you get some 5/16 course thread bolts and flat washers the right length.
Nice wheel by the way... |
01-13-2017, 04:21 PM | #3 |
I would always recommend using a steering wheel puller. I know other have their special ways of removing them, but I don't recommend any of them.
01-13-2017, 04:34 PM | #4 |
yes you need a steering wheel puller, you should be able to get one at autozone , buy it dont rent it ,then you have it forever
01-13-2017, 08:01 PM | #5 |
or the two person way..
put the nut back on but not tight, just flush with the shaft end.. and while one person is pulling on the wheel , the other gives the shaft/nut a good smack with a hammer.. pop it's loose, take nut off and remove.. same idea that works on tie rods and ball joints.. |
01-13-2017, 09:14 PM | #6 |
Thank you for the quick responses! The puller got it done.
01-13-2017, 10:37 PM | #7 |
You know I figured the same thing, bought one, got this far, hooked it up, and it came off so easy I'm positive I could've just pulled on it.
1969 C10 SWB Stepside, 350, TH350, FiTech Go Street Fuel Injection |
01-13-2017, 11:15 PM | #8 |
01-14-2017, 12:30 PM | #9 |
steering wheel pullers are way overrated I've removed thousands of steering wheels and hubs by myself without ever needing one// you just need to b able to outthink it
01-14-2017, 01:35 PM | #10 |
I've tried to outthink my column but it always ends up in a stalemate, just like our staring contents. I use a harmonic balancer puller with skinny bolts, but whatever works!
01-14-2017, 09:09 PM | #11 |
I don't like to stress out steering wheels by jerking on them too hard. It can cause cracks in the finish of the wheel. The puller saves those worries.
01-15-2017, 08:40 AM | #12 |
Old member
Puller's are cheap. They don't put stress on the wheel as mentioned.
