82 Silverado clean up
So here's my 82 Silverado.thats been parked for a while it was my daily driver. Til it blown a head gasket so I fixed that than.then it needed a lot more work so I parked it for a month and then I got the jimmy then the jimmy became a restoration project so I need the c10 back on the road. To start the list The cooing system is a mess full of rust bad tstat fan clutch stuck on and a smell hose leak by the heater core.and the carb needs to be rebuilt timing is off and oil pan leaks bad and brakes need to be adjusted and a flush so here's the start to the work on the truck.
Re: 82 Silverado clean up
Got some work done on the c10 today.Fixed the cooiing system flushed with new fresh antifreeze new tstat and fan.then I started on the WORST part of the truck.the oil pan spent an hour getting it off.than you got to get the old gasket off the block.�� huge pain in the you no what.
Are you going to use a one piece oil pan gasket?
| Bookmarks |
