Old 01-13-2017, 09:54 PM   #1
Alex V.
Alex V.'s Avatar
More heavy hauling with the Oneton
With the recent very moist weather my driveway was in such bad shape I said "Enough is enough, ain't waiting for the landlord no more!" and hauled some gravel. Hauled two loads of 3/4" clean, one 1.31 tons and one 1.51 tons - here's what the second (3,020 lbs.) looked like with the 3,900 lb. springs, still almost 2" off the auxiliary overloads.
Older guy manning the gravel yard made some small talk about the truck and a few heavy Chevys he'd owned, an '84? and an early 90's one of which had a 454 with nearly 400K on it when he quit using it.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 01-13-2017, 10:23 PM   #2
Re: More heavy hauling with the Oneton
Nice, the one ton-er's are beasts. One of my 1 ton duallys sports this on the tailgate, not many of these out there.
Old 01-13-2017, 10:27 PM   #3
Alex V.
Alex V.'s Avatar
Never seen that but it's pretty darned cool! What year is it and exactly how is it equipped?
Alex V.
Old 01-14-2017, 12:01 AM   #4
1988 V30 loaded silverrado 454/400 18,000 thousand original miles, I'm second owner, bought from a long time member and good guy.
Old 01-14-2017, 12:40 AM   #5
Matt Man
Matt Man's Avatar
Even though my truck is a half ton, it hauls over 1000 lbs pretty easily, rides alot better with the weight back there too.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-14-2017, 12:43 PM   #6
tucsonjwt
I have had that much on my 3/4 ton but it was dragging low in the back (8600 GVW.) I limit my loads to 2000# now because that is all I can lift with my dump conversion.
tucsonjwt is offline   Reply With Quote
Old 01-14-2017, 03:18 PM   #7
Alex V.
Alex V.'s Avatar
Yep, after having 2,600 of wood and 2,700 of gravel in it recently, and then upping it to 3,000 on the last load, I wouldn't want to routinely, knowingly haul more than that in bulk form - as much because I'm trying to keep the bed in good shape as anything, though I still have a thousand pounds left before I exceed GVW.
Alex V.
Old 01-14-2017, 06:54 PM   #8
1970pelle
1970pelle's Avatar
But its pretty cool knowing you have a truck that can handle just about anything you can throw at it. With in common since, which you have shown.
Last spring when Lowes/Home depot have there mulch on sale for .99 a bag. I hauled several full pallets, for two friend's and one for myself. One pallet at a time of course, it made my truck squat.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 01-15-2017, 02:19 AM   #9
Alex V.
Alex V.'s Avatar
Unhappy Re: More heavy hauling with the Oneton
Oh, yes - it may ride like a buckboard but every time I hook up to or load something up I'm glad it has every piece of HD equipment it does.
Funny story related to Lowes - BIL works there and once saw an individual insist on loading two pallets of shingles in his '07+ 1/2 ton Silverado. First pallet made it squat, and after loading the second one and finding the truck wouldn't move, they removed one pallet and it would move but sat noticeably lower than before. Woops.
Alex V.
Old 01-16-2017, 11:20 AM   #10
LT7A
That sounds cheaper than a flip kit for lowering my half ton. Maybe I'll take it to Home Depot and overload it. I have that same 15k Trailering Special package and badge on my parts Suburban. Heavy duty stuff.
Good to see your truck out earning its keep. It's in great shape. I like how you protected the bed.
