What front wheel size will look better
I have 315/60/15's out back that are 30" tall... what size would look better up front
225/60/17 225/65/17
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Re: What front wheel size will look better
I would do 235 75 15 upfront but I prefer a level look with a wider tire outback
70 SWB STEPSIDE 70 BLAZER 09 challenger |
![]() Join Date: Oct 2014
X2 on the 235/75 15. That tire will be 28.9" tall, 1" shorter than rear.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
I'm doing sort of a drag look, with 17s up front...the rears are 315/60/15's
And I have a 2.5" drop spindles up front and 6" springs out back,
The 225/60's will be 27.6" tall and the 225/65" will be 28.5" tall. With either one you shouldn't have any rub problem on the drop spindles.
Thanks...you think the 27 in tire would look better, or the 28
I'd prefer the 28.5 cause it will fill up the wheel well for a better look. Also you'll get a little more roll out when you go into the staging lights at the strip.
Thanks, that's what I needed to know....
