Old 01-14-2017, 01:24 PM   #1
DPete
DPete's Avatar
Door corner patch
I have seen them online, can't find now for some reason. The little lower inner corners where the seal goes. Where did I see them?
56' 3100 shortbed
DPete is offline   Reply With Quote
Old 01-14-2017, 10:58 PM   #2
EVILSTANK
Re: Door corner patch
Have you looked on LMC Truck?
EVILSTANK is offline   Reply With Quote
Old 01-15-2017, 12:04 PM   #3
dsraven
A pic and/or a yearseries would help. Inner, outer, front or rear of door would also help.
Old 01-15-2017, 07:49 PM   #4
DPete
DPete's Avatar
Yep checked LMC, Saw them somewhere 56' 3100
56' 3100 shortbed
Old 01-15-2017, 08:04 PM   #5
MARTINSR
MARTINSR's Avatar
That looks easy enough to make from scratch.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-16-2017, 01:45 PM   #6
EVILSTANK
check these out
https://www.c2cfabrication.com/produ...FdWNfgodH8oLKg
1959 Apache 3100 Fleetside short bed
235 l6
Old 01-16-2017, 01:48 PM   #7
EVILSTANK
Here's the passenger side
https://www.c2cfabrication.com/produ...oor-skin-patch
235 l6
Old 01-16-2017, 03:29 PM   #8
dsraven
I would suggest a little sandblast treatment of the back side of the door skin while you have the part cut off and before welding in the new part. are you doing the whole lower, front to rear, or just a patch made from the new panel?
Old 01-17-2017, 11:41 AM   #9
DPete
DPete's Avatar
Made one as mentioned, I saw the whole panels, thought I had seen just the corner somewhere. Thanks
56' 3100 shortbed
