10-14-2003, 10:53 AM | #1 |
71 DELUX
wood block drop...rear
Since I am uncertain about how much of a drop I want on my truck and on a tight budget, I have to cut costs as best I can. One thing I refused to do was spend $60-70-80 on a drop block "kit" consisiting of two extended U-bolts and two non adjustable rear blocks.
The best rear block kit I've seen is the DJM one for roughly $45 and comes with six .5" blocks, giving adjustabilty on each side from .5" to 1.5". Yet in even in California, with taxes, handling and/or shipping fees...it still ends up around $60. Fortunatley I found a cheaper solution. I had two U-bolts made yesterday and bought some hardwood at my local home store and was able to create my own adjustable block kit for under $30. I will still create blocks out of metal in my own garage and stay under $40. Just an FYI for any of ya-all out there with kids, homes, spouses. other toys or other expenses that try to get in front of your project truck! |
10-14-2003, 01:54 PM | #2 |
Progress = 0%
Good idea. I used some wood blocks as temporary lower bag cups on my '67! I have since made some metal ones but I they did the trick when I was setting up the front suspension.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
10-14-2003, 02:54 PM | #3 |
71 DELUX
Thanks...
Yeah, I won't leave them there, but since the underside really does not see any water or moisture (but heck, the bed is wood) I figured that some nice solid wood "would" do the trick. Unfortunately that same home store does not sell aluminum strips any thicker than 1/8" so I'll have to do some shopping for 1/2" pieces if I want to make the next set of blocks myself too. |
10-16-2003, 08:39 PM | #4 |
Try Blue Collar Supply on Florin-Perkins Rd for alum. stock. Very reasonable also cheap Grade 8 hardware.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
10-17-2003, 02:49 PM | #5 |
71 DELUX
Thanks NEON, saw them in the phone book. There is also a place over here off business 80 that I may try first, since it is on my path to and from work. May even call or stop by there today! That other place is very close to where I had my U-bolts made.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
10-26-2003, 01:16 PM | #6 |
Aluminum
Blue Collar supply on florin perkins in Sacto Has all kinds of metals -nuts bolts -stanless . maybe you know about this source. good luck Dean
11-02-2003, 08:07 AM | #7 |
F.A.S.T. president
I made my 2" blocks today out of some 2x3 1/4" wall rectangular tube and welded them on the traillering arms. I aso welded the seam in the trailering arm. After I made the blocks I must of stared at them for an hour tring to decied if I should weld them on for extra strength.
11-02-2003, 10:15 AM | #8 |
I had new u-bolts made at a local shop to lower mine down..........cost wasn't that bad...........
you can have them put threads as far as needed.........cut off the excess.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
11-03-2003, 11:29 AM | #9 |
71 DELUX
Yep, it is fairly easy to get this done without buying a pre-made kit. I installed my .5" plates/blocks last weekend (x4) on each side. Decided that I did not want 2" of block drop, only 1.5" so I removed one from each side this week. With the 3" spring drop the rear of my truck is now contently sunk 4.5" total. I like having the option of going up and down as I figure out tire and wheels sizes.
