New battery tray fitment
Hey all,
I got my new battery tray for my 62 but I can't for the life of me figure out how it fits in there. I am attaching photos for clarification. I do have a new radiator but the tray itself rests on the inner fender and is about 1.5-2" above what I think is one of the mounting holes. However the inner part of the bracket (near the radiator) looks like it stands off the radiator support panel by about an inch. In some pictures I have seen the back of the bracket appears to mount flush with the support panel. Anybody got any good pics? Did I get a wrong piece by chance? |
Re: New battery tray fitment
Unfortunately I do not have photos of the battery box on my computer, however, I can easily tell you the new radiator and the custom mounts for it you have are in the way of installing the battery tray. The pocket which has a piece of square tubing welded into it is for the edge of the battery try to fit back into. Your radiator is bolted to this square tubing. Hopefully someone else chimes in in with pictures. I am sure if you look thru some builds you will see what I am trying to describe. You will have to do some rework to that tray or find an aftermarket box to use.
#3 | |
![]() Quote:
Thanks for clarifying what I was afraid of... ![]() |
I don't know if this helps but you can kind of see where the taller end of the battery tray tucks up inside the cor support. in the second photo you can see where it bolts in.
