Old 10-14-2003, 10:58 AM   #1
68Bowtie4x4
68Bowtie4x4's Avatar
Chevy rearend question
I'm wanting to know if the 67-72 Chevy 4x4 1/2 ton front and rearends can be swapped out with 73-up 1/2 ton front and rearends? Do they have the same spring pad width? Is there any difference in the lower shock mounts? I know the pinion yokes are different and would require an offset u-joint, but need more info. I'm trading my 89 K5 lifted Blazer for a 68 Chevy SWB 4x4 pickup and it has 5.13 gears front and rear with detroit lockers in each rearend. I want to go to 4.10's, but want to know what my options are.
Thanks for the help,
Doug
72 Chevy Cheyenne K10 4x4 LWB, 4" lift kit, 350/350/NP205, rebuild in progress.
68Bowtie4x4 is offline   Reply With Quote
Old 10-14-2003, 01:03 PM   #2
krue
Designated A-hole!
krue's Avatar
I can't help with your question, but I am sure you will find it on here!
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-14-2003, 06:44 PM   #3
crazy longhorn
Fabricate till you "puke"
C to C on the spring pads on the longhorns, 1 tons, & 4x4s should be 40"(67-72). the width on the 73 up trucks diff will work, but the spring pads need to be relocated(I think they are 42 1/2" center to center. The later (73 up ) 1 tons should still have the 40" C toC on the pads.....that doesnt help much tho unless you want a duallie. you will also need to relocate the shock mounts, as the 73 up are fore & aft. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
