Old 01-15-2017, 07:45 AM   #1
WB72
Before and After
WB72's Avatar
Trailing Arm Crossmember Modificaation - Pic included
So I am doing a slam on a 72 c-10, this is a low budget build, so I am not going to spend unnecessary money if possible.
I have steel, I have experience in welding, I just want your opinion.
Why don't we cut the low part of the Trailing arm cross member flat and reinforce it with 1/4" flat bar? As I said, it is going to be slammed, so I don't think there as any reason I still need this part to hang so low.
See red line where I want to cut and add the flat bar.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 02-07-2017, 03:05 PM   #2
ChuckLee
Re: Trailing Arm Crossmember Modificaation - Pic included
this is done regularly actually. good thinking though. cut it and weld some flat bar on there.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 02-07-2017, 10:25 PM   #3
68c10airstream
68c10airstream's Avatar
Isn't that the top area when it was originally installed?? Or do you guys remove it and flip it around and now the top is the new bottom??
68c10airstream is offline   Reply With Quote
Old 02-08-2017, 11:07 AM   #4
SCOTI
SCOTI's Avatar
Correct. The image does show the line drawn @ the top but I'm betting it was just a quick job & just for illustration purposes.
Guys that lay frame using factory T/A x-members do usually 'flatten' (plate) the section that hangs below the frame as well as extend the top if running a 1pc d-shaft.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-08-2017, 02:57 PM   #5
sangell
Here is what I did.
sangell is offline   Reply With Quote
Old 02-12-2017, 01:37 AM   #6
WB72
Before and After
WB72's Avatar
Thanks for he replies. I'm glad my head is working in the correct way.
Yes, that is the top, sorry for my photo editing abilities.
I like what you have done with yours SANGELL.
66,000 miles.
Alberta, CANADA
