01-15-2017, 11:59 AM | #1 |
Good fitting black carpet???
Going to buy new black carpet for the 66, any advice on what to buy or not to buy?? Thanks its a 66 factory auto that will have 67/68 buddy buckets.
01-15-2017, 12:14 PM | #2 |
Re: Good fitting black carpet???
Many retailers sell the carpet kits which are all made by the same manufacter. Mostly, it's a matter of finding your best deal. I got mine thru Rock Auto, and I went for the "mass backed" option which is a heavier plastic on the floor side of the carpet.
It wasn't a perfect fit, but it was pretty close. (Maybe it was the installer). Another tip I have is using a cheapie electric woodburner or soldering iron to make the holes for your seats and etc. |
01-15-2017, 04:09 PM | #3 |
It's Better With Nitro
The Auto Custom Carpet sets fit better than the knock off ones I've installed in the past. I also use my soldering iron (knife tip) to cut the holes for the seat bolts, etc.
01-15-2017, 04:16 PM | #4 | |
Moderator
01-15-2017, 05:05 PM | #5 |
Yes, the last couple I purchased through Stock Interiors.
01-15-2017, 05:56 PM | #6 |
Just used Stock Interiors for the black carpet in my '63 - high hump. I too got the thicker mass backing. I also got the piece for where the gas tank used to be. Fast shipping. Overall Im very happy with the fit and noise reduction. X3 on the hot iron. I used an icepick and propane torch from under the truck.
Worked great. Id use them again.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
01-15-2017, 06:48 PM | #7 |
Moderator
I'd love to see that behind the seat carpet. What did you do on the corners?
01-15-2017, 08:51 PM | #8 |
This is the most recent kit (with the back panel piece) purchased as I took it out of the box to relax inside the cab (nothing is attached or glued yet in the photo). There is enough material to cover into the corner well.
01-15-2017, 09:45 PM | #9 |
Hey VIN63, is the last pic of a Stock Interior or ACC carpet? I see you got the rear panel cover too. Was your rear panel attached with velcro tape?
Rocknrod; Ill get pics tomorrow although the seats are already in. I left some material for the corners after I trimmed the sills. Ill probably fold it down into the corner well later. The biggest problem that I has was finding a place (warm enough) that I could lay the carpet out so that it could "regain" its formed shape. Mine spent a week in front of the fireplace. The dog kept laying on it and messing it up.
01-16-2017, 02:59 AM | #10 |
I personally would recommend against using TrimParts molded carpet. Perhaps others have had better experiences but mine was not good. Here is more about my carpet and experience with this company.
http://67-72chevytrucks.com/vboard/s...d.php?t=724803
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
01-16-2017, 09:08 AM | #11 |
Yes, there was the strip of Velcro at the top of the carpet. I will use some industrial strength hook and loop adhesive to further support the install.
01-16-2017, 07:43 PM | #12 |
Great info guys! Thanks, nice work Vin63!!
