Old 01-15-2017, 04:10 PM   #1
FRCvette
lowered front today
I put 3" lower springs on the front of my truck today. Everything went pretty good except drivers side spring won't stay seated in upper spring pocket when truck is jacked up. Took two floor jacks to get it right, one under cross member and one under lower A-arm then lower at same time to hold spring in place. Anyone else have this problem? I am concerned that every time I jack up truck I will have problems getting spring back in position.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 01-15-2017, 04:21 PM   #2
Boog
laying low
Boog's Avatar
Re: lowered front today
From what I hear that's common with using the 3" drop spring. 2" stays put. I used 2 1/2" lowered spindles and cut 1 round off the stock springs on mine to get her down about 4 1/2". My springs stay put.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-15-2017, 04:37 PM   #3
RDrancher
RDrancher's Avatar
Shorter drop shocks or limiting straps would solve the problem.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 01-15-2017, 07:04 PM   #4
FRCvette
So if I install lowering shocks the coils won't drop out of place when jacked up? I stayed with stock shocks so far but if changing them out will help I will do that.
What are limiting straps and how would they work.
Thanks.
2004 SSR
2013 Silverado swb
Old 01-15-2017, 07:49 PM   #5
Shinysideup
Shinysideup's Avatar
The springs fall loose when the shocks ARE attached?
Shinysideup is offline   Reply With Quote
Old 01-15-2017, 08:25 PM   #6
FRCvette
Yes they do. I do have stock shocks. Driver side is worse than passenger side.
2004 SSR
2013 Silverado swb
Old 01-15-2017, 08:35 PM   #7
RDrancher
RDrancher's Avatar
Thanks.
Using the shock for a droop limiter isn't the best method, but unless you plan on getting airborne a bunch, it will work. To choose a shock, jack up the truck and measure the length of the shock just before the spring starts to pop out. That's the extension measurement. Then jack the truck under the control arm to get the measurement for compression. You'll want to find a shock that works within those parameters. Allow for an extra inch for compression so the shock doesn't bottom out and blow the seals.
Limiting straps are an offroad deal, but they'll work to limit extension on anything. You can mount them from shock eye to shock eye, or bolt them from the frame to the lower shock eye. You can make your own out of cable or strap, or buy them pre-made in any length. http://www.ruffstuffspecialties.com/catalog/LIMIT.html
Old 01-15-2017, 08:38 PM   #8
Shinysideup
Have a friend with those short springs and they dont stay put either. Why not use drop spindles and have correct geometry anyway?
Old 01-15-2017, 08:42 PM   #9
FRCvette
Don't plan on ever getting airborne. LOL Thanks for the help.
2004 SSR
2013 Silverado swb
