01-15-2017, 05:07 PM | #1 |
Hood hinge bolts
I'm getting ready to install new, powdercoated hood hinges. The existing bolts are all the same it appears. Can somebody tell me the exact description of these 9/16" hex bolt screws in order to order the right stainless version to replace these? Hate to go back in with the old bolts. Thank you.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-16-2017, 03:10 AM | #2 |
70+ ( Old Skool Club )
Re: Hood hinge bolts
Just a suggestion. Clean the originals up on a grinding wheel, ( vice grips hold em good while cleaning ) then prime and paint them whatever color you had the hinges powder coated. My hinges aren't powder coated but are painted and that is what I did with my bolts.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-16-2017, 04:05 AM | #3 |
Try Totally Stainless.
https://shop.totallystainless.com/ They have kits and specific hardware for our C10's. |
01-16-2017, 07:58 PM | #4 |
Thanks, guys. I just wasn't sure what to order if I went stainless. One thread listed them as 3/8 - 16 and another 3/8 - 24 thread. I think I will try the paint idea. My restored ones are silver/chrome coating with the springs gloss black.
01-16-2017, 08:45 PM | #5 |
go into ace hardware and match up with the stailess and pay as you walk out with the brand new shiny ones
01-16-2017, 09:52 PM | #6 | |
Old member
Lowes and HD will have them mounted on the rack close to the hardware section.
01-17-2017, 02:33 AM | #7 |
If I understand the question, the original bolts used on the hinge are 9/16" head tapered screws (i.e. bolts) with integrated washers. The screw threads are 3/8" x 7/8" & 16 TC.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-17-2017, 05:43 PM | #8 |
totally stainless sells them with the correct style dished head if that matters to you...if you dont care ace lowes etc have stainless 3/8 16 bolts in stock ...remember to put anti seize on them as stainless likes to gall in the threads
1970 short step c10 leaf spring 454 |
