Old 01-15-2017, 10:03 PM   #1
Kaysen
Need opinions. 89 k30 in tank pump issues.
Recently got an 89 k30. It's originally a tbi 350 truck that has been converted to carb with an aftermarket pressure regulator/gauge feeding the carb. The truck has sat for 3 years without running.
I'm not getting fuel out of the pump. Is there a way to test the pump in the tank and bypass all the computer and old wiring? I unplugged the pumps two wire electrical plug and connected a good battery to the gray wire and to ground but it still did nothing. I'm thinking it could be a bad ground on the pump but I'm not sure without pulling the bed. Any insight or advice? Thanks
The engine runs excellent if you keep the bowl full with a squirt bottle.
Kaysen is offline   Reply With Quote
Old 01-15-2017, 10:39 PM   #2
100%Chevy
Re: Need opinions. 89 k30 in tank pump issues.
Sometimes if the pump is stuck,you can try reversing the polarity.It may or may not work again.
Probably corrosion causing the problem.
I recently had to pull the tank on a 89 G-30 van because the pump was running but not pumping.The short hose on the sending unit was blown out!
These tanks are a pain to get out!
Govt.corn gas again.
Mike.
100%Chevy is offline   Reply With Quote
Old 01-15-2017, 11:51 PM   #3
Kaysen
Thanks for the reply. Yeah I know these tanks can be a pain, that's why I'll go ahead and just pull the bed. Plus I wanna put on a straight bumper, better hitch, and tidy up the rear wiring harness.
I would think that hooking power to the pumps gray wire and grounding to a freshly ground spot on the frame would kick the pump on as long as the pump is grounded properly. Am I correct or am I missing something?
Old 01-15-2017, 11:53 PM   #4
Kaysen
Also I hear no noise at all from the pump. Like I'm doing nothing at all
Old 01-16-2017, 12:26 AM   #5
hatzie
Moderator
hatzie's Avatar
You are correct. It's just a Weatherpack connector to the sender and pump hot lead. I have a handful of both male and female Weatherpack and Metripack terminals to in my test lead box so I can run tests without damaging the connectors.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-21-2017, 11:50 AM   #6
Kaysen
Well, finally got the bed off and found the issue. The pump is toast and the tank is filled with rust. Just ordered a new tank/pump kit from rock auto. $200 bucks including shipping with new straps and lock ring kit. Hopefully this'll make it driveable!
