View Poll Results: What should I do first?
Air Ride 11 31.43%
Bodywork and Paint 14 40.00%
LS Swap 10 28.57%
Voters: 35. You may not vote on this poll
Old 01-16-2017, 02:28 AM   #1
CaptainMorgan_SOS
Opinions on which direction to go with my GMC.
As the title suggests, I am looking for what direction to go with my 67 GMC SWB. I am at the point to where I have 3 options,each of which will cost me about the same, but I can only afford to do one of them right now.
Option 1: Air ride. Looking for a full system that includes new trailing arms (so I can replace the leaf springs), allows 4 corner manual control, but is also self-leveling. So far I am looking at:
- PB Level 2 front and rear deluxe kits combined with their Accuair E-Level kit with touchpad
- Thorbros E-Level kit with touchpad combined with PB Level 2 deluxe rear kit
- Pro Performance Pro 2 kit with E-Level, touchpad, two 3 gallon tanks and exo mounts
Option 2: Paint and bodywork. Send the truck off to someone to go ahead and do the bodywork. Would also like to get the truck painted either medium green (original color) with cream grill, wheels, and bumpers or a charcoal grey with black wheels, grille, and bumpers.
Option 3: LS Swap. This would include picking up a "low-ish" mile 6.0 with all accessories, wiring harness, and ECU. Then sending it to the machine shop to be rebuilt and beefed up a little, sending off the harness to be refit for this truck, and send the ECU off for a good tune. I would need a new EFI ready tank that would include the fuel pump and sending unit, Dirty Dingo engine mounts, and a Silverado radiator with electric fans. I'd do the install myself but farm out the other stuff.
I can only afford to do one of these options at the moment so that is what the poll is for. What would you recommend?
Where I stand: I am leaning towards air ride because the engine is in good shape and I could do the rockers, floor pans, and cab corner myself while I have the bed and cab off the frame. Currently the truck starts and runs great, shifts smooth, and handles like a runaway train off the track (read: badly). I've got the parts in the garage to add power steering and power brakes; I just need to get around to doing it.
Specs on the truck: Late 90s GM Goodwrench 350, Edelbrock intake, Vortec heads, 600 Holley Carb, pretty nice sounding carb, long tube headers, new-ish exhaust, NV4500 trans, 12 bolt rear with 3.55s, leafsprung rear, straight body, and unknown drop spindles in the front. No AC, no heat, no radio, no power steering, no power brakes. Here is the truck in question along with its current condition:
Driver side rocker:
Passenger side rocker:
Passenger side cab corner:
Gauge cluster came with the truck. Gauges are nice, but I don't really dig the look.
Only other dings on the cab. Has a bend in the drip rail right there too.
Super inconvenient gas cap.
Bike is currently for sale to help fund part of the truck.
Replacement body parts I currently have. Both front fenders have already been replaced. Waiting on hardware to put in the inner fenders.
CaptainMorgan_SOS is offline   Reply With Quote
Old 01-16-2017, 02:55 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Opinions on which direction to go with my GMC.
My advice is do what ever feels right to you. Its your truck and you have to live with what you do. Remember if you decide to sell it down the road people will not have the same vision as you had/have for your truck. If you are on the fence about which direction to go drive it a while longer and take more time to decide, there is no rush.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-16-2017, 04:06 AM   #3
CaptainMorgan_SOS
Mostly what I am looking for is advice as to which would be the "proper" first step in restoring the truck.
Well, I am not "restoring" it in the true sense of the word; the truck seems to have been pretty pieced together in various stages throughout the years. It was originally medium green with a straight 6 and 3 on the tree and now its running a late 90s 350 crate motor and a 5 speed on the floor. One of the fenders I replaced was a 69 or newer fender that had the side marker hole filled. There is sheet metal riveted over the top of a couple small holes in the floor right at the edge of the door. The bed and hood look to have started life as a light blue color, while the cab was medium green; the doors were, at one point, this weird neon green color. I guess I am looking to restore/modernize it a bit by upgrading the suspension and drive train, as well as taking it down to bare metal everywhere I can and repainting it.
My initial thought is that I should do the suspension first. Start from the ground up. This way I could also clean up and paint/coat the frame, replace tie rod ends, bushings, body mounts, etc. Next, I would figure would be the engine/drivetrain. Once that is complete, then I figure bodywork and paint. This would then be followed by wiring, lighting, and then interior.
Am I on the right track? Or should my order of doing things be rearranged somehow?
Old 01-16-2017, 12:27 PM   #4
palallin
Currently the truck .... handles like a runaway train off the track (read: badly).
Has it occurred to you that maybe this is the place to start?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 01-16-2017, 01:10 PM   #5
CaptainMorgan_SOS
Well, I may have over exaggerated on this a bit. In reality, it handles like one would expect for a 1967 GMC without power steering or power brakes to handle (with what looks to be many of the original steering parts still in place). Could probably use new ball joints and TREs. So if I did the suspension or engine swap, I'd likely convert it over to rack and pinion steering at the same time.
Old 01-16-2017, 01:14 PM   #6
davepl
davepl's Avatar
Make it mechanically sound before you do any of these three (by which I mean reliably and safely starting, driving, running down the highway, etc). You know, ball joints, tie rods ends, steering box, tires, all of that.
Then make it look good.
Then make it faster.
Then make it cool.
In that order. Which to me means the order should be mechanicals, paint and body, then engine swap, and then ride height change.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-16-2017, 01:19 PM   #7
onebigjohn
onebigjohn's Avatar
First look at works together....Motor swap/mock up/install goes hand in hand with suspension. Difficult to work around a flawless body doing all that. Just my $.02
onebigjohn is offline   Reply With Quote
Old 01-16-2017, 01:44 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
There really is no "right way" to start. It all will depend on your budget, your skills, and mostly how much free time you have.
Just wing it... it will all come together. Don't let someone else guide what you want to do to your own rig.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-16-2017, 03:52 PM   #9
projectking
projectking's Avatar
Personally I'm a fan of building it exactly how I want it and then blowing it apart for paint. Saves from having it apart for too long and loosing focus.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-16-2017, 04:22 PM   #10
nastety92
If it were my truck I would do the LS engine swap first. Then down the line do suspension work, then body work last.
If you are ever looking to change up the look of your truck for Cheap, look into Plasti Dip.
Nick
nastety92 is offline   Reply With Quote
Old 01-16-2017, 05:31 PM   #11
GASoline71
GASoline71's Avatar
That's what I am doing with mine. Could eben drive it around for a bit if I want to. Then when I'm gonna get ready for paint, I'll blow it all apart again.
Trying to explain this concept to my wife and she thinks I'm nuts.
Gary
Old 01-16-2017, 06:59 PM   #12
RenoKeene
Florida Edition
RenoKeene's Avatar
In your case I would do the suspension first. It is the base for everything else you have planned. They say "Ground Up" for a reason.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-16-2017, 07:11 PM   #13
Grumpy old man
Grumpy old man's Avatar
Start at the frame / suspension /brakes then drive line ,then paint,glass ,seals with interior last.
Grumpy old man is offline   Reply With Quote
Old 01-16-2017, 07:25 PM   #14
OARNGESI
OARNGESI's Avatar
Step 1 suspension step 2 drive train step 3 paint step 4 Terror in all honesty the paint and body will give you the most resale value when you do the motor be sure to budget in painting the firewall since that work best.
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-16-2017, 08:16 PM   #15
mooseknuckles
mooseknuckles's Avatar
I agree..paint should definitely be last. and since the motor sounds like it is decent shape I would do the air ride first. make it cool, everything looks better bagged! Then a LS swap and you'll never want to get out of it.!
mooseknuckles is offline   Reply With Quote
Old 01-16-2017, 11:48 PM   #16
palallin
Fair enough, but my '67 Chevy w/out PS handled like a dream and went right on straight down the road without me holding the wheel (once I replaced a lower control arm u-bolt). There is no reason yours shouldn't, too, after you replace any worn parts. But none of that other stuff matters if the truck won't go where you point it.
Old 01-26-2017, 11:43 PM   #17
CaptainMorgan_SOS
Thanks for the info. I thinking I am going to go with taking it down to the frame, cleaning it up, painting it, and then convert the rear to trailing arms and run bags front and rear with an Accuair e-level kit. While I am at it I'll replace the tie rods up front, the tie rod adjusters, pitman arm, the upper and lower ball joints, replace the front wheel bearings, and then convert it to power steering and power brakes. I'll also be changing out the rear gears to 3.73s and I'll replace all of the bearings and races, so include the outer axle bearings and axle seals. Will probably change out the body mounts to poly ones.
The engine is running great, so it's not necessarily something that needs to be addressed for right now. I may even look into rebuilding the current engine and throwing on a FiTech system with their sump under the hood. As for the body, while I am cleaning up the frame, I'll try my hand at replacing the cab corner, the rocker panels, and the floorboard sections right by the door and foot well.
So you are right on the worn parts. Went to mess around with it the other day and found out the passenger side front wheel bearings are shot! The lower and upper ball joints looked pretty worn out too. heard some noise on the passenger side the other day as I drove really close to a brick wall, so I jacked it up and sure enough, the wheel had a good wiggle when pushing on the top and bottom of the tire.
Old 01-27-2017, 01:03 AM   #18
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I think you've answered your own question in your initial thought. Start at the bottom and work up, make it safe and reliable working your way up. Then you wont be back tracking doubling up on your work load. Try not to get to anal about it either. I think thats where alot of guys loose interest in their builds, they nit pic the damn thing to death and never get to drive it while it sits in their garage for years. Get that suspension and drive train sound and watch how many compliments your work in progress gets at the gas pump. Keep it simple and keep it pleasurable, one thing at a time..."Just Sayin"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-27-2017, 10:30 PM   #19
CaptainMorgan_SOS
And now the question is: what suspension system should I go with? I'll probably start up a thread in the suspension forum... I am just sitting at information overload at the moment. AVS, Porterbuilt, Thorbros, AZ Pro... too many options haha
