Old 01-16-2017, 10:44 AM   #1
nastety92
67 Suburban 04 Suburban Engine
I'm in the process of having the motor from the 2004 Suburban pulled and then it's going to be installed in my 67 GMC Suburban C10. Just wondering if we will be able to reuse the stock exhaust manifolds or if I need to find a set of TBSS, Envoy or Rainer exhaust manifolds?
The 04 Suburban has a 5.3 with 4L60E in it. It's all going in my 67 Sub.
Thanks,
Nick
nastety92 is offline   Reply With Quote
Old 01-16-2017, 02:51 PM   #2
NC_John
NC_John's Avatar
Re: 67 Suburban 04 Suburban Engine
Thanks,
Nick
Will probably mostly depend on the engine mounts you decide to go with.
I have the CPP sheetmetal mounts/perches with the dirty dingo adapters and there seems to be plenty of room to run manifolds or headers. With the older tubular mounts fitment was a major problem.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-16-2017, 02:52 PM   #3
nastety92
Thanks for the reply John. I was looking at the Dirty Dingo adapters and I was wondering which mounts to go with. I guess I will look more at the CPP sheet metal mounts/ perches.
Thanks,
Nick
Old 01-16-2017, 05:31 PM   #4
NC_John
NC_John's Avatar
Thanks,
Nick
Nick- I'll post a couple pics to show clearance tonight to give you an idea.
1970 C-10 LWB "Blu"
Old 01-16-2017, 05:34 PM   #5
nastety92
Thanks John that will definitely help me see those parts in place.
Old 01-16-2017, 07:39 PM   #6
truckdude239
truckdude239's Avatar
I have a 71 c10 with dirty dingo mounts on the stock 71 mounts i had to use tbss manifolds the stock manifolds wouldnt clear my enginr was a 04 silerado 4.8
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-16-2017, 07:52 PM   #7
chuychevy82lwb
I have a 82 square with 5.3 used some ebay adapters (1 inch setback ) and used 2010 camaro long tube headers
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 01-16-2017, 08:42 PM   #8
NC_John
NC_John's Avatar
Here's mine (during some initial test fitting). The factory manifolds fit easily.
1970 C-10 LWB "Blu"
Old 01-16-2017, 08:53 PM   #9
ls1nova71
ls1nova71's Avatar
There are no manifolds on it in those pics? From my experience, the truck manifolds kick out too much at the rear and will hit the frame. Maybe if you shove the engine all the way back to the firewall they won't, but I wanted the engine in the factory location.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-16-2017, 09:03 PM   #10
nastety92
Thanks for the pics and the info guys. I'm hoping I can get the factory manifolds to work if not I'll look for a set of TBSS or similar stock manifolds.
Old 01-16-2017, 09:15 PM   #11
NC_John
NC_John's Avatar
I did test fit with the factory manifolds (just didn't take pictures since I am going to run headers). With these sheetmetal perches and the dirty dingo adapters there was a ton of room on both sides. The only thing I have to do is relocate the a/c compressor up top.
1970 C-10 LWB "Blu"
Old 01-16-2017, 09:42 PM   #12
72MARIO
72MARIO's Avatar
The 2010 Camaro manifolds fit great. I actually used the down pipes and dual cats on my suburban. I also used the sliders from dirty dingo and set my engine almost all the way foreward to allow the stock ls fan and original 1968 shroud to be used
There are some.pitcures in my build link
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-16-2017, 10:36 PM   #13
dec010974
dec010974's Avatar
Just for thought, if there is some interference, you can always notch the frame. It's just an idea.
dec010974 is offline   Reply With Quote
Old 01-17-2017, 09:44 AM   #14
Hart_Rod
Hart_Rod's Avatar
+1, Also if you are running a DBW pedal, take a look at my pedal adapter bracket: http://67-72chevytrucks.com/vboard/s...d.php?t=651123.
Hart_Rod is offline   Reply With Quote
Old 01-18-2017, 12:38 AM   #15
izzy_Britton
izzy_Britton's Avatar
I was looking for these CPP engine mounts. I do not see them on their website, do you happen to have a part number for them? I really like the looks of those, it appears there is a LOT more room around these mounts than the factory mounts.
thanks in advance.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 01-18-2017, 07:29 AM   #16
NC_John
NC_John's Avatar
thanks in advance.
-Izzy
https://www.summitracing.com/parts/c...del/c10-pickup
(You can minimize the abuse from those morons at CPP by buying from summit)
1970 C-10 LWB "Blu"
Old 01-18-2017, 08:06 AM   #17
izzy_Britton
thats funny stuff right there.
I think i may have reacted to your post a little to quickly. I have an 86, these SHOULD fit, right? I have always been under the impression that the cross members and the motor mounts are pretty interchangeable between the 67-72 and the 73-87/91 well more specifically 63-87/91, like if you wanted to put disk brakes on your old drum truck just roll all the parts from under a square under your drum and be done, direct bolt up... so i assume, well i am asking, if these fit the squares as well as they fit the 67-72? make sense? or do ya know?
I may just go ahead and order them just to find out for myself if no one knows for sure. i emailed CPP last night, but after your comment above, i dont expect to hear from them about specifics.
-thanks in advance - Izzy
Old 01-18-2017, 10:39 AM   #18
NC_John
NC_John's Avatar
not building a squarebody, I'm not sure of fitment beyond the 67-72's. I'm sure somebody around here knows though.
1970 C-10 LWB "Blu"
Old 01-20-2017, 01:17 PM   #19
binford
Active Member
The stock manifold needs slight mod to fit. Using a torch and crescent wrench to make frame mod. here's a video of a swap.
https://www.powerblocktv.com/episode...p#.WIJEHk0zWUk
First question would be are you going to run A/C? if so then read this thread its a later year but same concept
http://67-72chevytrucks.com/vboard/s...d.php?t=413855
By moving the stock frame mounting bracket back an inch or so the A/C compressor will fit, otherwise you need to by the adapters to mount the compressor on top of the engine. The 67 should have pre drilled holes to move the mount back, but it's more like 2+ inches, so I might need to just drill some holes. I have not dropped the motor in yet to see just how it fits. Between the weather and other things needing attention.
Maybe next weekend.
binford is online now   Reply With Quote
Old 01-20-2017, 03:31 PM   #20
NC_John
NC_John's Avatar
Maybe next weekend.
I couldn't see any way of fitting the A/C compressor in the low passenger side location on mine so I got the relocation kit to put it up top. Got the Kwik Performance bracket with the Vintage Air kit through MCB.
I think the whole thing is not going to be real pretty but I am building the LS for function over form.
1970 C-10 LWB "Blu"
Old 03-31-2017, 08:00 AM   #21
nastety92
Does anyone have a part number of the actually motor mount that they used with the CPP perches and Dirty Dingo sliders? We were trying to use an older Corvette style mount and it would not fit at all.
Thanks,
Nick
Old 03-31-2017, 08:16 AM   #22
72MARIO
72MARIO's Avatar
I don't have a part number but you can search by year 1967-72 small block mounts worked fine with my DD sliders. You need to make sure you have small block engine stands not big block or 6 cylinder.
2005 TAHOE DD
Old 03-31-2017, 08:18 AM   #23
nastety92
Thank you, I'm using the CPP Perches that I purchased at Summit and Dirty Dingo adapters.
https://www.summitracing.com/parts/clp-6372mp-sm
Old 03-31-2017, 08:31 AM   #24
72MARIO
72MARIO's Avatar
The CPP sliders look like a diffirent mount than 67-72 trucks the trucks use one 7/16 bolt in the center. The CPP mounts look to use the long bolt thru the mount and frame stand
. Sorry I can give you a solid answer on what mount to use.
2005 TAHOE DD
Old 03-31-2017, 08:33 AM   #25
nastety92
Thanks for trying anyway. I think these are the correct mounts. I was just talking to Summit Technical assistance online.
https://www.summitracing.com/parts/e...114r/overview/
