01-16-2017, 12:27 PM | #1 |
flywheel removal for a 57 235
i am totally stuck. there are 2 bolts at the top/ inside of the bellhousing that i can't get to without removing the flywheel. trouble is- i have zero idea how to remove the flywheel. there are supposedly some sort of pins holding it in place? i don't see any- just some holes. i tried tapping on it- no result.
any photos available of what i need to do? thanks a lot, Scott |
01-16-2017, 02:19 PM | #2 |
Moderator
Re: flywheel removal for a 57 235
I did this recently on a 235 that we put in a 63. You have to take the flywheel bolts out, remove the flywheel, then you'll get the other bellhousing bolts.
01-16-2017, 02:33 PM | #3 |
Where are the flywheel bolts
I removed the 6 around the shaft but cant pull it off |
01-16-2017, 03:56 PM | #4 |
The flywheel is just a very tight fit to the crankshaft. Rap it a few times with a hammer and it will start coming off.
01-16-2017, 08:44 PM | #5 |
I figured it out
Thanks so much Scott |
