Need a bit of brake booster ID help.
Yesterday I climbed in the 86 and hit the brakes after starting, and heard that wonderful sound of gush. I knew right then what it was, the booster had let go. Watched the vacuum gauge while touching the brakes, what vacuum none. I had started to notice a slight issue on take offs, a tip in hesitation. Now I know.
Anyway I looked at RockAuto and there asking me to look for a JB6 or JB7. I have the sheet still in the glove box and I don't see this abbreviation code. Or even a mention of brakes on the list. The door sticker says nothing also. Could someone point me in the right direction please. Thank you Ken 1986 C20 4X2 5.7L,700r4,3.43, Silverado
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
Post Whore
![]() ![]() Join Date: May 2015
Re: Need a bit of brake booster ID help.
Scroll down to the "j" section and check for your gvw...maybe this will help..http://tlentz.oldsgmail.com/rpotext.txt
#3 | |
Ken
One more question, what is the correct color for the booster on a 1986 C20 Silverado ? I ordered a AC Delco reman. from Rockauto. With shipping under 80 bucks if anyone is interested.
Thanks Ken
Installed the new reman brake booster today. I order it from Rock Auto, and its a AC Delco unit. I sprayed it with matte gloss clear before installing. Only took about an hour total.
What a major difference in braking. Ken
