Old 01-16-2017, 03:13 PM   #1
cottonme173
cottonme173's Avatar
Double Roller timing chain on stock cover??
I have been frustrated trying to find an answer to this. I am rebuilding a 1977 454 out of a C25 pickup. Stock cast block and large oval heads. I have a double roller timing chain that I am putting on. My engine machinist said that the cover will work, but I am not sure and I don't want to screw anything up. Is there a way I can measure fitment? Does it move when running that I would need to account for more room?
Help!
cottonme173 is offline   Reply With Quote
Old 01-16-2017, 04:14 PM   #2
GRADYS Performance
GRADYS Performance's Avatar
Re: Double Roller timing chain on stock cover??
What brand and part number chain do you have?
GRADYS Performance is offline   Reply With Quote
Old 01-16-2017, 04:36 PM   #3
kwmech
I just put a double roller in my 454 without any issues under the stock cover
Old 01-16-2017, 05:06 PM   #4
cottonme173
Well, that's good news! Hopefully mine will work also :-)
Old 01-16-2017, 05:07 PM   #5
cottonme173
I will have to check when I get home tonight
Old 01-16-2017, 06:27 PM   #6
c10454
I also installed a double roller on my 76 454 with the stock timing cover. I used a summet SUM-G6610-9
c10454 is offline   Reply With Quote
Old 01-17-2017, 01:38 PM   #7
cottonme173
I have the Engine Pro Performance Timing Chain Set
08-3024-3
Old 01-18-2017, 06:36 PM   #8
GRADYS Performance
That should fit under a stock timing chain cover.
Old 01-18-2017, 06:54 PM   #9
vht
I've ran them with a stock cover many times.
vht is offline   Reply With Quote
