Active Member
![]() Join Date: Dec 2015
rear disc conversion- what master cylinder?
I've got an '83 2wd that came factory with disc/drum, non-power, and 1' rotors. I'm putting a rear disc conversion kit in it (SSBC basic) and want to know what master cylinder, or master cylinder/booster, to use
![]() ![]() Join Date: Oct 2014
Re: rear disc conversion- what master cylinder?
I used an SSBC kit a few years back on another make truck. It came with instructions on how to modify the proportioning valve. That's all that should need to be changed out/modified.
Active Member
Great! Thanks- still waiting for it to arrive so I hadn't seen the instructions. I wanted to pick up the master before it arrived. Even better if I don't need anything more!
| Bookmarks |
