Old 01-16-2017, 09:43 PM   #1
urmyboyblue
1984 C20 front wheel seal/ bearing help needed
I am trying to install new wheel bearings and seals on a 1984 C20 Suburban. I bought my parts thru Rock Auto- new hubs with races already installed, bearings are National A-35 and 1510S, the seals are National 8974S. My problem is that the seals contact the inner race of the inner bearing when I try to install them. Before the seal seats in the bore, the lip is contacting the bearing race. I have looked and the bearing is seating on the race, so I don't understand why it is not working. If I press the seal in until it just misses the inner race of the bearing, it is not half way into the bore. The inner race feels like it is against the lip in the hub. So any ideas? Pictures or measurements would be nice too. If you have a known good hub, could you post a picture of the seal and bearing in the hub? Or a measurement of the depth from the back face of the hub to the inner race. Any help is appreciated!
urmyboyblue is offline   Reply With Quote
Old 01-18-2017, 11:23 PM   #2
Jstock85
Re: 1984 C20 front wheel seal/ bearing help needed
I just completely redid my 85 c10 with rock auto parts. Hubs with races installed, seals, and other brake and steering parts. Everything fit fine and installed perfectly. Is it possible you have th wrong part? They have solid customer support (they'll actually answer the phone when you call). Give them a call and see if there's a chance of a mix up in parts.
Jstock85 is offline   Reply With Quote
Old 01-19-2017, 02:29 PM   #3
urmyboyblue
I would call Rock Auto but I bought this stuff a couple of years ago, I don't even know the brand name of the hubs as I thru the box away. I might see if a parts store around has a hub in stock and see if it is the same.
Old 01-19-2017, 03:38 PM   #4
Jstock85
Keep the hubs at all cost (being the most expensive part). Races and seals are cheap. If you need to tap the races out and start over completely with new races and seals that you know match.
