Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 01-17-2017, 04:27 PM   #1
paulspickupparts
49 Chevy 1/2 Ton Parting Out
I have decided to crush out my older trucks to make room for more later model parts. With the advent of reproduction and China influx it is time to let them go. I will keep this truck around for a week or so . For now I have the following parts.
Wiper Linkage $35
Seat Skirts $35
Cowl vent $35
Hood Hinges $40 Set
Inside Window Frames $50 Pair
Column Drop Clamp $20
Pitman Arm $35
Road Draft Tube $35
Valve Cover $25
Throttle Linkage $40
Foot Stomp Starter Linkage $40
Front Bumper Brackets $50
Side Cowl Vent $35
Glove Box Hinges $20
Radio Speaker Cover With Trim $40
Igintion Switch With Key $25
Other Parts All parts plus shipping. Paypal or USPS Postal M.O. . Fast shipping with USPS Priority or Fed X ground on the bigger items.
Last edited by paulspickupparts; 01-17-2017 at 04:30 PM. Reason: Shipping Addition
paulspickupparts is offline   Reply With Quote
Old 01-17-2017, 08:20 PM   #2
sofilofi
Junior Member
Re: 49 Chevy 1/2 Ton Parting Out
Is the wiper linkage complete?
sofilofi is offline   Reply With Quote
Old 01-17-2017, 09:06 PM   #3
paulspickupparts
I will make it complete . Set of under dash wiper linkage , bezel and outside arms. Should buy the little rubber gaskets that go on the cowl. Also will need the new wiper blades as these are poor. Thanks
Old 01-17-2017, 10:31 PM   #4
sofilofi
Junior Member
Cool.How much shipped to 90604?
Old 01-17-2017, 10:53 PM   #5
paulspickupparts
I will not know till I get it packaged and your zip. Send me your zip and I will get a quote.
Old 01-17-2017, 11:20 PM   #6
sofilofi
Junior Member
My zip is 90604.
Thanks.
Old 01-17-2017, 11:21 PM   #7
paulspickupparts
Shipping via Prority Mail is $14.
Old 01-17-2017, 11:26 PM   #8
sofilofi
Junior Member
Would you take $45 shipped?
Old 01-17-2017, 11:41 PM   #9
paulspickupparts
No
Old 01-18-2017, 12:04 AM   #10
sofilofi
Junior Member
Ok,no problem.
$49 total right?
I can do paypal.
Old 01-18-2017, 12:09 AM   #11
paulspickupparts
Ok , Pm sent with paypal information
Old 01-18-2017, 10:28 AM   #12
paulspickupparts
Linkage shipped via USPS Priority Mail. Tracking # sent . Thanks again.
Old 01-18-2017, 10:32 AM   #13
sofilofi
Junior Member
Cool,thanks.
Old 01-18-2017, 10:10 PM   #14
e-rock
How much you want for the 2 gauges?
87 chevy crew 4x4 (sold it)
1953 chevy
Build thread. http://www.67-72chevytrucks.com/vboa...d.php?t=725442
e-rock is offline   Reply With Quote
Old 01-18-2017, 10:22 PM   #15
paulspickupparts
$75 for the pair. The speedometer works but will need a needle and face kit. I tested the temp gauge on the cluster and it works , other gauges untested but look good. Would be a good set to restore.
Old 01-18-2017, 10:23 PM   #16
e-rock
I'll pass. Thank for getting back to me.
1953 chevy
Old 01-19-2017, 10:54 AM   #17
paulspickupparts
Added Gauge Cluster $40 And Speedometer Temp gauge tested and works. Will need to have a face decal kit and bezel . The speedometer and odometer both work. Will need a decal kit and needle (farmer brown added a tootpic) . $40 .
Old 01-21-2017, 02:25 PM   #18
exploderjim
exploderjim's Avatar
How much for the parking brake handle, mount and rod assembly that connect to the floor? 14304
exploderjim is offline   Reply With Quote
Old 01-21-2017, 02:33 PM   #19
paulspickupparts
The park brake setup sold locally . Did you just need the pull rod under the dash or a complete setup? Thanks
Old 01-21-2017, 02:51 PM   #20
exploderjim
Just need the pull rod.
Old 01-21-2017, 03:20 PM   #21
paulspickupparts
I usually sell them with the complete e-brake setup but have this lone one that I was starting to build another set. Would need light straightening . There are two little cracks (one on each side see photo) on the angle bracket. Good stud.$25
Old 01-21-2017, 03:42 PM   #22
exploderjim
Thanks for looking in to this. I have the bracket on my truck still. Was thinking of just threading a rod if I could. Probably just as easy at this point.
Old 01-26-2017, 02:04 PM   #23
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
How much for cut out cowl section on drivers side where vent goes, (with 4" or so material on outsides to work with)with a vent door, etc. Want to install one on my 51. Need everything for complete functioning install. 27587 zip code.
--Josh
Old 01-26-2017, 03:11 PM   #24
paulspickupparts
Hi Josh , I have the one pictured from a different truck for $50 . I do not think it has enough suround for what you are trying to do as you will need the complete pivot holder and inner kickpanel That is what I normally sell the door for by itself. I can cut the one out the truck pictured but it may be on Friday. Price will be more depending if on how much I take. I recommend also getting the inside cowl panel also as there are at least two different styles of this so recommend a matched set. Will try to get the other one cut out either on Friday or Saturday. Thanks Paul
Old 01-26-2017, 04:33 PM   #25
STOCKISH
STOCKISH's Avatar
Thanks man, Im going to try to find one complete a little nicer before I commit, Thanks again.
--Josh
