Old 01-17-2017, 07:41 PM   #1
Speedracer39
Speedracer39's Avatar
72 c10 non- ac htr assy rebuild
I have one arm that is broken on my heater control assembly also The plastic cover this for the fan control window is cracked and broken I was wondering if this also comes in the rebuild kit or if it is available. Thanks
Speedracer39 is offline   Reply With Quote
Old 01-17-2017, 08:05 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 c10 non- ac htr assy rebuild
You can buy the arm kit but not sure about the lens. I have never seen it offered but you never know.
I'd do a parts request on the parts board.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-17-2017, 08:13 PM   #3
Speedracer39
Thanks, I've been doing some searching they call it a bezel mine is nasty and cracked wasn't sure if it would be more cost effective rather than rebuild just replace it.
Old 01-17-2017, 09:43 PM   #4
Andy4639
Old member
Andy4639's Avatar
I would just replace it myself. Lot less time spent in the long run and you start with all new stuff.
