![]() Join Date: Apr 2013
Help ID Power Steering Pump
Wondering what year this pump is for and application. Is it maybe for a car. Thanks Nathan
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
![]() Join Date: Jan 2007
Re: Help ID Power Steering Pump
big block truck setup
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
As in C50 truck. Thought it might be a '72 but it's different than the one that came in my C10
i'm not real sure about specific years/models but i have a 71 c20 and just sold a 78 c30, both big blocks, and both have setups that look just like that.
Ttt Anybody else know what year this pump is from or anything about it? What I noticed is where the oil inlet is is different then a '72 and the three lines on the back of pump. Two return and one pressure looks like.
looks like the one that was on a 72 gmc 2500 that i used to have with a big block in it..
2 return lines usually mwans it's from a hydroboost system.
And,vans also use a remote fill like this one has. I've several 80's C-30's with this type pump set-up. Mike. ![]() |
#8 | |
I'm not seeing 2 returns just a high and low pressure port. But the double pulley resembles a larger truck pump. Find the part #'s on the pump or pulley and that should point you in the right direction.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
There's 2 return nipples sticking out(one with the hose attached and one without a hose).
Then there's the threaded hole for the pressure hose connection. Many set-ups like this one use a belt from the crank to pump and another belt from the crank to the pump and then on up to the alternator and back around the water pump. Mike. ![]() |
#10 | |
OK, At that time I've had too much coffee and I guess I just didn't focus hard enough too notice the extra nipple. Either way the part #'s should get him close too a yr. Or model.
Thanks for the help. I searched 73-87 form and like Mike said I think it is eighties big block. Midniteblues good call on part numbers that should nail it down. I am going to put it up for sale and didn't want to sell something I was wasn't 100% sure off. Thanks Again. Nathan
