Shorty Block Hugger Headers
Anybody have any Pros or Cons on using these style headers? My only thinking was that that are harder to get to when taking off the pipes for any reason.
John Sacramento Area 1969 C10 Fleetside |
Formerly yellow72custom
I have heard that block huggers won't clear the engine mounts in these trucks....maybe someone else will know for sure.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Resident Young Old Dude !
They do make some that are made for our years,and a few of the guys here are running them, I have seen a few sets on E-bay that WILL NOT fit.
Ron |
Those Ebay sets were the ones I was looking at... I think mostly it was the price of these headers that attracted me.
Fabricate till you "puke"
That set wont fit/clear the eng stands. Slammed 67 has a set on his truck(sandersens I think)....they fit nice, but are a little pricey. on the shortie headers, you will trade off a little low/mid range tork, for the extra ground clearance. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Im not looking for ground clearance, since Im not slamming it. Just looking for that price range. All the other headers around that price are used and WELL used. So it was just an option.
John,
Check out Summit's own line of headers, They are pretty reasonably priced in comparison, and you know they are a brand name made for summit. Plus, you could drive up on a day off and pick them up. Ron |
I dont know what you want to spend on headers, but there are severals full lenghts sets out there for a decent price. I am running a set of painted Hooker comps(around &140-150 through summit or jegs). The headmans are also a decent header, & a few less dollars. To get into coated headers, you will send a few bucks. if you were close to il , i have a good used set of headmans(cheap). my longhorn is a 3/5 drop, with more drop on the plans......the dr side collector hangs a little low for what I plan to do. Good luck,crazyL
drag it like you stole it
i have summit block huggers.. $75 i believe
negative camber //LA\\ |
#10 | |
Block headers for our year of trucks?? I asked last time I was there, ( Summit 2 weeks ago) But the guy said they didn't have any block hugger headers that would fit, But that idiot, also said they didn't have any spark plug wire looms, ( you know the aftermarket fancy type) I looked around for a while, found a different kid, and he showed them to me. AMAZINGLY !! right behind the guy on the counter that I had asked before ! Did I have a few things sarcasticly to say to him.. Like Hey Bud,,,, You need to remove your sun glasses inside, you missed seeing the pieces I asked you about and they are right behind you ???!! OHHHH, You don't have sun glasses on do you? sorry my mistake !
I know, I can be a smart @SS... Ron Quote:
#11 | |
Low & Slow
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
Lotik, did you have to trim the eng stands to fit the block huggers? crazyL
#13 |
Can't you use 3/4 length Chevelle headers on these trucks to resolve the ground clearence issues?
#14 | |
![]() Join Date: Jul 2003
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
#15 |
i didn't have to trim anything, they bolted right up. someone told me that i have my motor in th v6 position, but i am not sure if that would make a difference. my motor is pretty close to the firewall.
#16 |
lotik
anyway you can post pics?
#17 |
Ok, here is what you do, get those block huggers and a couple of turbos off an late 80's T-Bird Turbo Coupe. Weld a the correct flange on the collector of the header. Flip the headers upside down and mount the turbos. Now run your exhaust
Just sitting here contemplating contemplation. Last edited by 68 Suburban; 10-14-2003 at 08:47 PM. |
#18 |
here you go
#19 |
F.A.S.T. president
![]() Join Date: Sep 2003
I think you guys are looking for "shortie headers" not "block huggers". They make shorties for are trucks they are swept back for the correct clearence. Huggers are used on early rods (20's 30's 40's) because of the narrow frame rails they need to "hug the block" and the collect is staight down the two center cyls because the staight axle or Mustang II suspension usally sits alot father forward then our trucks.
#20 |
mine are definately block huggers
#21 | |
F.A.S.T. president
The one thing I like about the huggers is I think they are the only one I have seen come chrome from the factory and have also seen them in stainless. |
#22 |
![]() Join Date: May 2002
i'm using the newer style mounts, the ones that are the clamshell type mounts, and the block hugger headers won't fit. the driver's side tube 1 hits the mount. i'm going to the mid-length to full-lenght headers
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#23 |
I think for the best price for full length you can't beat Heddman (thick flange). A friend of mine was running the Summit brand and he was having problems with exhaust leaks (headers to block). When he called Summit to order another set for his car the salesman highly recommended HOOKERS (that is what I am running on my car:ceramic coated) For A lowered truck like ours I would get the Sanderson from someone like Early Classic. The worst thing about driving my car and the headers is SPEED BUMPS
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
#24 | |
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
#25 |
Unregistered User
![]() Join Date: Dec 2001
Pat - the 6 cyl position is further back toward the firewall, which is also the 4x4 v8 position. I don't think he meant to say v6, but I'm only assuming.
Mike
71 SWB Stepside SB400/TH350 |
