Old 01-18-2017, 11:26 PM   #1
rockyrivermark
Bench seat foam repair?
1970 C10 bench seat question
The drivers side foam is too soft and unformtabke. Simply wore out I'm guessing. The rest of the seat foam is firm and I good shape.
Question is
1. Has anyone cut off the drivers side foam and stacked and glued new foam to biuld it back up.
2. I saw a video of a clothes steamer that brings old foam shape back to life. The steam makes the foam expand and enlarge again. Has anyone trucked this technique?
Any advise appreciated.
Thanks. Mark
rockyrivermark is offline   Reply With Quote
Old 01-19-2017, 12:54 AM   #2
LongBox
Re: Bench seat foam repair?
I'm in on this thread. My 69, with the "full foam" seat, has problems on the driver's side, and it sounds the same as yours. The foam has basically collapsed to the point where it is too soft, and the driver sits in a kind of hollow area.
Solutions please.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 01-19-2017, 09:20 AM   #3
midniteblues
midniteblues's Avatar
Check the seat springs almost every Dr side I've seen has broken springs.
Cheap fix.
Jy's are filled with truck seats with good foam and springs.
Find some foam and trim you'res out and patch in a good peice.
Some 3m spray contact cement will bond it together extremely well.
To cut and shape foam a powered kitchen carving knife works wanders and a very rough sanding disc helps too.
I've found even old recliners can have springs that can be wired Or clamped onto broken ones to help stiffen them up.
This is gonna be very redneck here but on my older boys 67.
Around the sides of the driver side it was really weak. You would Almost slide off it either forward or towards the door.
I used a round pool noodle and slid it around into the outer springs and it wrapped around the side and it give alot more support to the seat.
Poor man's way but it worked well.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-19-2017, 09:43 AM   #4
RDrancher
RDrancher's Avatar
Subscribed to this one.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 01-20-2017, 08:18 PM   #5
Gromit
Hey I got this one! Because this topic was my very first post to this forum
Here is a link to my old post with lots of photos..
http://67-72chevytrucks.com/vboard/s...d.php?t=677940
Do a search in the archives for Bench Seat Foam because I learned later that others had already posted similar and better information than me on the topic.
There are lots of links but just check 'em all and you'll learn everything you need to know on the topic from this most excellent board.
Gromit is offline   Reply With Quote
