Old 01-19-2017, 02:00 AM   #1
Alberta65
Speedo cable and oil pressure removal
Ok maybe I'm doing something wrong here...
Just unscrew speedo cable by hand?
Is there a lock but on the oil pressure line?
I can't get my fat face in there to see what's going on...
Alberta65 is offline   Reply With Quote
Old 01-19-2017, 07:47 AM   #2
vince1
Re: Speedo cable and oil pressure removal
You must be referring to the back of the instrument cluster. Speedo cable nut should come off by hand or maybe pliers. I don't have an oil pressure gauge so can't help with that one. Mirror and flashlight?
What vehicle you got? Mine's a 66 250 4sp fleetside 3.07 but has a long way to go to be made pretty.
vince1 is offline   Reply With Quote
Old 01-19-2017, 07:55 AM   #3
PGSigns
PGSigns's Avatar
Oil pressure line is screwed in. About a foot down the oil pressure line is a coupling that you may be able to find. I use a 3/8 wrench and just unnscrew the line. It can be a pain. The speedo will just unscrew but once the nut is off it may not want to pull back. It will come out the back when you slide the cluster out. You need to remove all the switches before trying to pull the cluster.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-19-2017, 10:57 AM   #4
Alberta65
Sorry ya I rushed through that post, yes Im removing the instrument cluster to paint the bezel.
1965 C10 that I'm redoing by the way, build is called "Just Learning" heres where Im at....
Jimmy
Thanks Jimmy, do you mean about a foot down the line there is a coupling? haha ya i figured out the little puzzle of removing all the switches so Im just left with the speedo and oil pressure now
