Powerglide Kickdown Adjustment
Could anyone post a video of how to adjust a Powerglide kickdown rod linkage? Mine does not downshift to first when dropping accelerator to the floor. Transmission shifts smoothly up and down driving normally. I have a 307 with edlebrock 600. Thanks in advance!
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
![]() Join Date: May 2005
Re: Powerglide Kickdown Adjustment
come on guys how about a little input! I need this information too. Tia
Found this on a chevelle forum.
1. Have a friend hold the gas pedal all the way to the floor. Make sure the carb is opened up fully with the gas pedal depressed all the way. 2. Under the car, pull the lever forward, till you hit the spring loaded "detent". Then pull further ahead till you have the lever ALL the way forward, overcoming the spring tension. With those 2 things done, the rod should slip between the two holes, one in the carb linkage, the other in the trans. lever. In other words, with the throttle fully open, the lever should be fully forward.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
