Old 01-19-2017, 05:59 PM   #1
Custom06
Custom06's Avatar
1986 Chevy C10
I need some help from the GURUS in here. We just rebuilt a sbc 350 with Comp Cam 268. Everything else is stock on the motor with the exception of the intake, Edelbrock Performer. Installed it, starts great, runs great in Park but has a hesitation when taking off in gear. We adjusted the idle on Carb and adjusted the Timing as well. We just can't figure out the hesitation. Also, we had the Holley rebuilt over a month ago prior to the rebuild. We have replaced the Cap, rotor, coil and wires so far. Only things lacking is the Carb and spark plugs. We're thinking of trying out a used Dizzy to see the difference. Any help at this point would be helpful. . . . . . . .
Custom06 is offline   Reply With Quote
Old 01-20-2017, 07:38 AM   #2
cadillac_al
Re: 1986 Chevy C10
The GURUS here are going to want to know your timing specs and vacuum. Myself, I would try a known good carb and then you would find out your holly is messed up.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-20-2017, 11:49 AM   #3
SkinnyG
SkinnyG's Avatar
Re: 1986 Chevy C10
Try adjusting the idle while it is in gear. My Q-jet hesitates if it is even the teeniest bit too rich. Next would be the accelerator pump cam or adjustment or (not as likely) the diaphragm itself.
Don't be afraid to try different initial timing.
OH! - Full manifold vacuum to the vacuum can can help too. <<<< try that, it's easy and free (you will need to lean the mix a bit more once you do)
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
