Old 03-30-2002, 12:14 AM   #1
Super Chevy
Super Chevy's Avatar
Post 315/70r15 on my truck
i was thinking about getting some Truck Comp T/A's 315/70r15 for my truck http://www.bfgoodrichtires.com/catal...ck_ta_hr4.html they say on there site rim size 8-10" i got 8.5's and was woundering if anyone hs pics of 315's and do i have to extend my wheelwells?
thnx
72.
www.superchevy.cjb.net
1972 Custom Deluxe/10
mild 350: Hedmen headers and dual 3" exhaust ,harlin sharp roller rockers ,MSD ingnition ,Mallory dual point K&N 14x4 air cleaner ,Holley 600 4bbl ,Edelbrok Proformer intake
TH350 with lock up verter and 1600 stall
American Racing 15x8.5 and michelan 28x8.55
CHEVY makes HORSEpower,while ford makes ponypower
Bowtie or nothing!
Super Chevy is offline   Reply With Quote
Old 03-30-2002, 12:39 AM   #2
neonlarry
neonlarry's Avatar
Post
I looked at them too, but I don't think they would fit. I may be wrong, but I think anything wider than a 285 will stick out past the fender. The widest tire I have seen on a 67-72 was a 295/50-15, and it stuck out about 2''. I may be wrong, but I think a set of radial t/a s would be better. Those tires are so wide I am not sure what you would put them on, but anyway that's just my opinion.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-30-2002, 12:45 AM   #3
Super Chevy
Post
ive seen someone on this board that had a blue truck (cant remember the name?) that had 315's and all he had to do was extend the wheelwells,hopefully he will read this
72.
Old 03-30-2002, 01:19 AM   #4
neonlarry
neonlarry's Avatar
Post
If you don't mind extending the wheelwells they would probably work. I wasn't saying you shouldn't use them, just that they were kind of wide for a stock truck. If you did use them, what would you put on the front? There is a 285/65 I think, but any of the other sizes would be about 4'' smaller than the 315s.
Old 03-30-2002, 09:38 AM   #5
70cst
70cst's Avatar
Post
I have 275x60x15 (15x8" rims) Goodrich on my truck without stickout.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-30-2002, 12:27 PM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
I've seen 295s and 305s on trucks without any body mods and both stuck out a little from the truck...
On mine, 275/60-15s fill it up nicely out back with '80s stock 4x4 rims, 15x8 I believe. Front is 235/60-15 (or 245? dang, can never remember...the Suburban uses one, my truck uses the other...) because the disc conversion I have from Early Classic shoves the wheels out a bit more than stock, any bigger rubs on the fender on semi-big bumps. Same rims.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-30-2002, 12:31 PM   #7
Project1970
14.1 @ 96MPH
Post
Oh, and that Sport Truck T/A looks interesting...how long have those been out? Anyone used 'em? I might be needing replacements for the Radial T/As soon...
Old 03-30-2002, 12:34 PM   #8
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
315/70's are alot taller than a 295/50 and are also narrower because of the 70 series. 295's are recommended for a 9.5 rim aren't they?
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 03-30-2002, 03:47 PM   #9
SCOTI
SCOTI's Avatar
Post
A 315mm tire is wider than a 295mm tire irreguardless of aspect ratio. The aspect ratio (or 70 in 315/70/15) tells you the tire sidewall height is 70% of 315mm. It's a simple formula:
315 div. by 25.4= 12.4"W
315 x 70%= 220.5
220.5/25.4= 8.68
8.68 x 2 + 15= 32.3"H or approx 32+/- depending on wheel width.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-30-2002, 05:20 PM   #10
ryan68
Certified Chevy Man
ryan68's Avatar
Post
I have seen a guy that tucked 315's by special ordering rims with the backspacing to within 1/8". And he notched the piece that holds the outer bedside to the inner wheel well a little.
68 Chevy CST (327,TH400) 3/5 drop
71 Suburban 4x4 (350,TH350) 33's
Check out my web site!!! http://www.geocities.com/cst68chevy/
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
ryan68 is offline   Reply With Quote
Old 03-30-2002, 05:35 PM   #11
Super Chevy
Post
yea,i looked into the reg Comp T/A's but then I'd have to order a 10" rim,the added sidewall on these allow me to run my 8.5 rim,the tire its self is 32x12 ,but BFG is known for over measuring,so its probably 31x11.5 or so
72.
