10-14-2003, 05:41 PM | #1 |
Radio Delete Plates?
Can anyone post a pic of what the RADIO DELETE plates look like, either on a truck or off. The PO of my truck cut the dash and I thought I could make it work until today when I trial fit the stereo, it was slightly too big and not even level. So now I need to come up with a new idea. I want it to go into the original spot.
John Sacramento Area 1969 C10 Fleetside |
10-14-2003, 06:36 PM | #2 |
Just sitting here contemplating contemplation. |
10-14-2003, 06:52 PM | #3 |
Where's my beer?
Here's a trick one installed by slammed67, pretty cool!
Half way open.. His truck is awesome. |
10-14-2003, 06:58 PM | #4 |
That a great idea chevy_fatman and thanks to you as well 68 Suburban. What kind of clips do they use, would it be enough to hold the weight of a stereo? I was thinking of using one of those and then cutting it correctly to mount the stereo. Or maybe just a piece of steel fabricated in. I just dont want it to look stuck on or......
10-14-2003, 08:29 PM | #5 |
back
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-14-2003, 11:00 PM | #6 |
Oh..... so do those tabs go into where the stock knobs used to be??
10-14-2003, 11:03 PM | #7 |
My other Love
to hold the deck into place you use the mounting sleeve in the hole, bend the tabs, that retains the front. The back is supported by a strap that mounts to a pre tapped hole in the back of the deck. The other end the strap i like to attach that to the big phillips head screws on the bottom of the dash
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
10-15-2003, 04:07 AM | #8 |
Black 72 Chevy
chevy_fatman
That is nice, I want to do that to my truck to prevent thiefs from taking my storeo.
72 Chevy, SWB, 350engine, TH400 |
10-15-2003, 05:53 AM | #9 |
I used my radio delete plate for a cassette deck faceplate by drilling holes for the control shafts and using a nibbler to cut out the front rectangle. Came out pretty good. I sprayed it flat black, but I think if I had to do it today, I would have left the delete plate the original rpo 516 orange. BTW I found the piece rattling around inside the passenger door.
10-15-2003, 08:47 AM | #10 | |
67 is sold
